03-22-2016, 06:06 PM
New bus shell cost from factory?
Wonder what a new bus would cost, from the factory, if you spec'd it without seats, without all the school warning setup, no windows and just steel sides where the windows would be....... basically just a shell to build from? I'm thinking of something like a Thomas since they're built in NC. I'm guessing in the $50k-$60k range. Anyone have any idea?
03-22-2016, 08:36 PM
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
If you don't get a definite answer tonight, I'll call and find out tomorrow.
03-23-2016, 10:11 AM
Depending upon type of bus, the length of the bus, and the options you want/need that cost will be anywhere from $70K to more than $100K.
Type 'C' buses will cost about $10K less than a Type 'D' FE and about $20K less than a Type 'D' RE.
The bigger the HP the more you will pay. Much like trailer tow packages on cars and pickups, when you order bigger HP it comes as a package. The package will come with a bigger transmission, bigger radiator, bigger transmission cooler, and possibly a bigger driveshaft.
Increased interior headroom can be optioned. I think Thomas has up to 24" more available. You can see some factory roof lifts on specialty buses like bookmobiles.
Transit slider windows with thermopane will cost more than school bus split sash drop windows. Tinted glass will be extra on split sash windows.
Window delete like a prison bus will cost more.
Air brakes will cost more than hydraulic brakes.
Larger brakes and auxiliary braking will cost more. Some auxiliary braking like exhaust brakes on a Cummins only cost about $150.00 more but it all adds up pretty quickly.
If you get air brakes rear air suspension is not a big cost option. It is standard on most Type 'D' RE buses. No air brakes and the air suspension option becomes a big cost option.
The current WA state price quote on a Type 'C' 60-pax bus is just over $88K. For a Type 'C' 77-pax bus the price is just over $93K. For a Type 'D' FE 84-pax bus the price is just under $100K. For a Type 'D' RE 84-pax bus the price is just over $112K.
Pass through luggage compartments add $3,200.00. Skirt mounted luggage compartments add about $1,300.00 per compartment.
Air ride seat adds $510.00.
240 AMP Leece-Neville alternator is standard. 300 AMP adds $950.00.
Vandal locks adds $350.00.
The standard floor is black. Non-standard floor is $1,200.00.
If you are serious about a brand new bus built without seats it is not going to be inexpensive. Ordering a bus right now you might see it before Thanksgiving if you are lucky.
You can usually go to a dealer like Midwest Transit and purchase a lease return for a considerable savings. It may not have every option you would like but they generally do not spe'c bare bones buses. The buses they get that get spe'c'ed with luggage compartments usually also come with big HP and highway gears. Year old buses save about $10K. Three year old buses about $30K.
I think the costs of seats might be around $5K
03-23-2016, 11:04 AM
Great info, thanks Cow. For that money you can buy a used Class A coach already outfitted. Might not be bulletproof like a school bus but will already be built and ready to live.
03-23-2016, 12:24 PM
Can buy a HELLUVA coach for less than that.
03-23-2016, 02:05 PM
Rated Cap: 2+1
Yeah, but then you have what most others have. "Dare to go your own way"
What a rush !! I have done my own thing the biggest part of my life, and at times it has cost me Family and friends and loads of money, am I happy Hell Yeah 99.9%
Of the time. I don't smoke, I don't drink very much, most of the time not at all.
And I only chase one woman now days..I'm old fat and happy and a little crazy.
And when I die I want to be buried up side down...my wife said I'm not good with directions anyway.
Finally pointed in the right direction for where I'm headed
And that's the truth
Don and Ellen
Plus one fuzzy faced kid (Poopcee)
03-23-2016, 05:17 PM
Chassis: All-American R/E
Oh but the inherent costs and problems you inherit with a coach are a whole different thing!
03-23-2016, 05:23 PM
IDK, man I've seen some amazing old rigs that I'd definitely rather be building out than a school bus. But my budget dictated the bus I got.
Had I $50k to spend, I'd not be as inclined to go with a low powered school bus.
To each their own. Just threw my 2cents in.
03-23-2016, 05:58 PM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
03-23-2016, 06:14 PM
and there you have it....... who knew Cowlitz was a bus salesman!?
03-23-2016, 08:49 PM
Engine: TE 444
Rated Cap: 12
for 12 K you can get an 82 blue bird wanderlodge
03-23-2016, 09:07 PM
Moderator
I'd be all over that bad boy...but I'm poor too. That's why I'm on skoolie.net
03-24-2016, 10:36 AM
Where's that Wanderlodge? Post a link if you have one.
03-24-2016, 09:05 PM
I've considered buying a Wanderlodge when I'm ready since they are built on a school bus shell. Randy Dupree has some nice ones on his site:
Blue Bird Wanderlodge and Motor Coach Brokering Service
One possible issue I see with buying an older bird like the one shown is usually it is well worn due to the age, which is reflected in the price, and often the maintenance history is sketchy if buying from a private seller and good records were not kept. If you look through many of the ones Randy has listed on his site they have been maintained and upgraded regularly, so although the cost may be $50k for a decent one it may be worth it if all the mechanicals have been recently maintained and upgraded. I have his site bookmarked to contact when I'm able to pull the trigger and make a purchase. I'll at least look at what he has in inventory.
03-24-2016, 09:22 PM
So let's say for about $70k you can get a new shell spec'd to your needs or a low mileage used bus a few years old. This is step 1 of starting with a bus with new or almost new mechanicals and possibly a warranty.
Step 2: let's estimate you can have someone do the rv conversion for about $50k in a few months time (thus saving you much time and allowing you to get going fully converted quickly).
So for approx $120k-$150k(added some on the high end if the build costs more), you have a fully converted rv, basically a new "ThomasLodge". This equals the cost of new Class A rv's but with a much better body and drivetrain. Damn, the cost of my first house was only $75k some years back! Course that didn't roll and I had to look at the same view every day for years
03-24-2016, 09:49 PM
Engine: TE 444
Rated Cap: 12
I bought this one from Randy back in 2011, engien only has 21K on it, mechanical's are good interior is worn, it was lived in
Engine: TE 444
Rated Cap: 12
It is my wanderlodge in my driveway in Cincinnati Ohio
03-25-2016, 11:06 AM
Interesting question, I've wondered about this since I'd rather pay more for less rust. It's good to know where the top end of the scale is.
Aside from not wanting all the seats, I'd rather start with this. The Transit-Liner is the same as the Saf-T-liner minus the school warning setup and side rails, fixed windows, and better seats.
Transit-Liner C2 (Type C) - Thomas Built Buses
03-25-2016, 01:28 PM
Sounds like they'll spec how the bus however you want it. I like the look of the plain white. And having no interior would be a great blank canvas to start with.
03-25-2016, 01:30 PM
Thanks Kubla. Do you have the Wanderlodge listed currently or is it an "everythings for sale for the right price"? What engine/tranny does it have?
