Old 08-24-2021, 10:59 PM   #1
No child left behind
Hi, I'm stuck!..does anyone know how to disable the " no child left behind "system from the computer and turn off the warning light in the dash...the beeping is driving me nuts! I have an 09 IC...
Tammy02187 is offline   Reply With Quote
Old 08-25-2021, 03:45 PM   #2
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
my 2004 bus different make/model and my only experience with the child check button?
i was able to trace the VANDALOCK wiring and found that if i connected the VANLOCK RELAY wire and the VANLOCK PILOT wire together that i was able to delete everything else related to that system.
good luck
Old 08-25-2021, 10:27 PM   #3
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
If your No Child Left Behind system is still intact, there is a procedure for stopping the beeping. In the IC buses I drove, it varied, but in general, it activated only after turning on your 8 way lights (the yellow and red ones on top, front and back, that flash alternately). After turning off your 8 ways, you shut the bus off. You then have say 30 seconds to go back and press and hold the button until you hear a beep. After that, the alarm is disarmed. Once you've disarmed it, it should not arm again unless you activate your 8 way lights.
You may need to get information on the model of the system and contact the manufacturer for the proper sequence.
Per removing it from the bus, I'm not sure. Mine was already removed.
Steve
Old 08-25-2021, 10:59 PM   #4
Thank you both!, I have an 09(per) title, tag says 07 so...? Anyway, there is , was no " button " to press in the back, there was however a plastic box with a buzzer and button at the door latch, that has all been removed, the bus will start and drive but now I have the " emergency light in the dash lit and a beeper somewhere in the dash going...still hunting!...lol
Old 08-26-2021, 04:30 AM   #5
Sometimes there's a considerable lag between when a bus (or its engine) was manufactured and when it was sold. Mine for example was built in '02 but is titled as an '03. A two-year difference would be unusual but not impossible.
Old 08-26-2021, 09:25 PM   #6
Ok!, I assume it's alright being two MVA's in different states accepted it that way so I'm not worried, just curious...thanks !
Old 11-26-2022, 07:11 AM   #7
Year: Don'
Coachwork: Don't have one yet
Chassis: Don't have one yet
Engine: Don't have one yet
Rated Cap: Don't have one yet
Did you ever figure it out. On my 2008 bluebird vision it sounds the horn too. Like you a load of wiring has been removed.
MarkCHI is offline   Reply With Quote
