HPOP while cranking is 3000??? Ive never ever seen it that high.. it will run that why when the engine is running under full load.. the reason i ask about HPOP during cranking is if for some reason your HPOP is draining down.. its happened to some of the ford guys.. what results is 0 or very Low HPOP pressure whole cranking till its cranked enough to refill the reservoire and generate pressure.. the HPOP will read perfectly once the engine is started because the pump is good, IPR is likely good and ICP reading correctly..
I don't think the HPOP is draining down, because I can crank the engine for 30 seconds with nothing. My understanding is that the HPOP res would fill pretty quickly, even if it was drained down. Also, there's no oil in the valley, etc. I realise it could be draining into the low pressure side of the oil system, but if the pump was working, it would refilll the res while cranking. I can check the levels Saturday morning when I go to start it, although I don't know what it "should" look like.
