Old 05-29-2019, 10:50 AM   #1
Year: 95
Engine: Bluebird
Not turning over, fix or tow?
Y'all have been such a lifeline.
I have to move this thing in four days. Just had a guy out to help fill the coolant because I wasn't sure about the bleed valves, and it starts but doesn't turn over. Usually needs a little gas but that's not doing anything. He said some things about glow plugs, then said well it doesn't have glow plugs, then he just sort of left. Thought he was a diesel mechanic but ok.
My driver has been supposed to come look at it for a few weeks now. He's booked to drive it Saturday. Can't find anybody with a shop to come out and if I'm going to tow it somewhere I'll just tow it 8 miles to the new site.
Or sell it. Maybe I'll just freakin' sell it. Anybody want a 74 seater '95 Bluebird with a stripped interior, new insulation & subfloor?
I got my plates from Vermont the other day but I haven't been to the DMV yet to make sure NC thinks it's an RV. I do have AAA with RV coverage.
Advice sought: tow or fix? How to best use AAA at this point given questionable title designation?
elliot_peas is offline   Reply With Quote
Old 05-29-2019, 11:22 AM   #2
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
What engine do you have?
CMORGANSKOOL is offline   Reply With Quote
Old 05-29-2019, 11:24 AM   #3
It starts but doesn't turn over?
If you have Vt. registration, N.C. has no say in it. Your insurance may though.
Old 05-29-2019, 11:26 AM   #4
HazMatt's Avatar
Chassis: IH 3800, 8 window
Boy's stressing.
Give him a break...
Old 05-29-2019, 11:32 AM   #5
Year: 95
Engine: Bluebird
Haha I flip them every time. Y'all go right ahead and get it out of your system, you're still nicer than Reddit.
Old 05-29-2019, 11:35 AM   #6
HazMatt's Avatar
If we can't solve the problem, yeah, you'll be there... [emoji41]
Old 05-29-2019, 11:43 AM   #7
Year: 95
Engine: Bluebird
The engine serial is 45095013 and I'm struggling to find an engine lookup online. Cummins from the serial though, right?
Old 05-29-2019, 11:50 AM   #8
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
So is it turning over? Clogged fuel filters? Is it turning over slow or fast? Are the batteries good and are they fully charged?
All of those things can be what makes the difference.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 05-29-2019, 11:53 AM   #9
Year: 95
Engine: Bluebird
Batteries are new as of a month ago and it's run a couple of times since I put them in. No idea about fuel filters. It makes the normal degree of initial noise, as far as I can tell from having just let it run without driving it, but does not then escalate to the second amount of noise. Depressing the gas pedal does not cause any change in noises.
Old 05-29-2019, 12:25 PM   #10
Coachwork: IC
Chassis: FE Bus
Luckily diesels require two things, (newer require 3)
Fuel, Air, and Electric
You can check to see if the fuel pump is working, check to see if the air filter is clear, and check if there's current to the injectors if you have electronic injectors.
This is your opportunity to dive head first into your first skoolie adventure.
I knew NOTHING about diesel engines when I bought my bus a year ago. So don't fear. I'm now confident I could tear mine down and do a rebuild if I had to.
Old 05-29-2019, 12:48 PM   #11
Year: 95
Engine: Bluebird
Please keep telling me this is an adventure.
Old 05-29-2019, 01:04 PM   #12
Cummins Quickserve: https://quickserve.cummins.com/qs3/portal/index.html
Old 05-29-2019, 01:34 PM   #13
Coachwork: chevy
Chassis: express 3500
Engine: 6.5 diesel
what work did you do on the bus since it was running last? I pulled the seats out of my bus and it wouldn't run after. I knew it had something to do with the work I just did. I was grinding the seat bolts off at the top and tapping them through the floor. there were 3 that didn't go through. I cut them flush and did flooring over them. I discovered when I was trying to hammer one down it cracked my fuel sender on top of the gas tank. it was a hairline crack but it caused the lift pump to suck air and no diesel was getting to the engine.
nixon186 is offline   Reply With Quote
Old 05-29-2019, 01:36 PM   #14
HazMatt's Avatar
Excellent advice! But, wow... what're the chances?
Old 05-29-2019, 01:51 PM   #15
Chassis: International 1753
Engine: 6.9 International
Crank is the term I think you're looking for. Crank is what the starter motor does to the engine until it either runs or the batteries die.
Starting is when the engine starts to burn fuel and you no longer have to hold the key over.
So lets start from the beginning. 1995 year bus with a cummins engine? Is it a 5.9 or 8.3? Did you do anything at all between now and the last time it ran?
Booyah45828 is online now   Reply With Quote
Old 05-29-2019, 02:04 PM   #16
The term came from back in the day when you stuck a crank handle in the front of the motor and cranked it till it "fired off" It cranks till it fires, or turn over till it starts.
Old 05-29-2019, 02:09 PM   #17
HazMatt's Avatar
Just mind the crank doesn't shatter your arm when the engine fires. Starts. Runs. Catches...
Goes, "vroom"
Old 05-29-2019, 03:35 PM   #18
a friend of mine from the UK calls it "Swinging" till it fires.. said his grandfather had an old crank start car and he would "Swing" on the crank in cold weather the first few times to get it to start...
Old 05-29-2019, 03:40 PM   #19
HazMatt's Avatar
Not the first image to pop up in MY mind regarding, "Swinging..."
Old 05-29-2019, 03:53 PM   #20
Goes, "vroom"
It's a ratchet end, it doesn't spin with the motor.
