Originally Posted by kromboy
...You can make...cables...
...[hollow-moon lizards]...
Semi-retired welder-fabricator here.
a)
Securing cable ends requires a swaging tool
These look similar to big bolt-cutters.
Some first-time builders attempt the unlikely using a hammer and chisel... tink tink.
Sure.
Then, after unfortunate 'issues', they visit a legit cable-maker.
b)
Instead of some mail-order nonsense dealing with hollow-moon lizards, ask at a battery shop or solar store.
Our preference is local-owned family-operated.
c)
Our rig is a 1996.
The Cummins 8.3 requires two Group 31.
After issues with pecker-heads investigating the exterior battery box, I fabricated a secure tray above the axle and between the frame rails.
We have room, so I added a third Group 31.
Simultaneously, I 'up'-graded all the cables to 4/0 (pronounced 'four ought') welding cable.
I also added a second 'ground' cable from the bank to the frame.
[edited to add]
Our introduction with plenty of portraits, plus our reasons for our decisions:
https://vanlivingforum.com/threads/e...8/#post-576110
