Old 08-13-2020, 09:08 AM   #1
Sraycwb's Avatar
Coachwork: International 3800
Ospho - Best application method?
After grinding down minor surface rust, am now ready to enter Ospho application stage.
What is the preferred method of application?
Thanks!
Sraycwb is offline   Reply With Quote
Old 08-13-2020, 09:41 AM   #2
Depends on the application. For the floor I just dump it here and there and use an old mop to spread it around. I also have an empty windex bottle full for vertical surfaces and hard to reach areas.
Old 08-13-2020, 09:55 AM   #3
Sraycwb's Avatar
Roger that. It's for the floor. I wire brushed the surface rust away. Thankfully nothing too entailed. My initial thought was spray bottles but doing the entire floor, I thought I'd be a little closer to the product than desired.
A mop definitely sounds like a sound idea, thanks.
Old 08-13-2020, 12:48 PM   #4
spray bottle causes enough volatilization that I always feel a mild burn in my throat while spraying into confined areas.
I'd pour some out and spread with a throw a way brush (which I'd save for the purpose)
David
The Murder Bus
Old 08-13-2020, 01:45 PM   #5
I forgot to add I only spray it if I have a mask and a prevailing wind or fan behind me.
Old 08-13-2020, 01:48 PM   #6
Year: 2008
Chassis: 0908S
Rated Cap: 28' 9 window
Ospho needs a follow up coat of paint. I used ospho for my floor and then gave a coat of rustoleum fence paint and I am happy with the result
I decided to use rustoleum rust reformer on the underside because I did not want to use ospho and then apply a second coat of another paint. I will use a pump type fertilizer sprayer when I start the underside
dwood443 is offline   Reply With Quote
Old 08-13-2020, 02:37 PM   #7
That's a lesson I keep needing to relearn...
I too often think "I'll be done before I know it"
David
The Murder Bus
