Old 02-04-2021, 07:21 AM   #1
Year: 2014
Coachwork: Ford e350 cutaway
Chassis: E350
Engine: I don't know
Rated Cap: 9 Passenger, plus driver
Paint removal
Hello! I have a 2014 e350 transit van that I just bought! I started taking the vinyl off and have most of that completed, I started to take the vinyl off the drivers side, and come to find out it is painted! Looks like there was some kind of body damage that was repaired, it looks like the van was backed into something. But not I can't get the paint off. Looks like a crappy low bid body shop job. What do you recommend to get the top layers of paint off without damaging the paint underneath?
Rainbowlove is offline   Reply With Quote
Old 02-04-2021, 09:06 AM   #2
s2mikon's Avatar
Engine: Cummins 8.3
Have you tried wet sanding? If it is a small area get some 320-400 wet and dry and water sand it by hand. You will see the layers as you cut though. If you are cutting through to fast drop back to 600 grit.
s2mikon is offline   Reply With Quote
Old 02-04-2021, 09:48 AM   #3
Year: 2014
Chassis: E350
I have not tried anything yet, I didn't know where to start.
Old 02-04-2021, 02:53 PM   #4
Chassis: Ford E450
Engine: V10 Gas
Is the body fiberglass?
Mine is fiberglass and I had to remove the vinyl wrapper, but there are two areas where they did some minor bodywork. I used a half inch, very sharp chisel and scraped the paint off.
Where the vinyl wrap refused to come off the painted stripe (over the fiberglass), I used the same technique but was much more careful.
I don't think there's any practical way to pull a top layer of paint off another layer. Sanding it, in my opinion, would never work to anyone's satisfaction.
