Old 12-11-2019, 11:21 AM   #1
Chassis: TC1000 FE
Engine: 5.9
Patching coolant line holes with a welder?
I just took the driver's foot warmer out and the two coolant lines running to it were connected by hose barbs to the main line. Is there any reason I can't just grind down the two barbs and patch them with a weld?
lebusmagique is offline   Reply With Quote
Old 12-11-2019, 12:04 PM   #2
Bigger question is why are you deleting the foot warmer? It's extremely important in freezing temps. Yes, a weld patch will work.
Old 12-11-2019, 12:11 PM   #3
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
I agree with Marc on the question of removal. I also think buying a cheap coolant hose union (cheap as in price, not quality) would be quicker & easier than welding two fittings together.
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 12-11-2019, 12:15 PM   #4
Chassis: TC1000 FE
Engine: 5.9
Pretty much had to to get at the rotten plywood underneath the driver's seat. I've still got dashboard heat and I mostly plan on chasing good weather too. And if I ever do find myself in super cold weather I can't imagine I'll be that cold with the engine right next to me and warm clothes on and dashboard heat blowing on me.
Old 12-11-2019, 12:39 PM   #5
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
Speaking from 5 Wisconsin winters experience driving flatnose Bluebirds, your upper torso will be fine with dash heat but your feet and legs will be FREEZING without the drivers floor heater.
I would look at options for retaining that drivers heater if at all possible imo.
Old 12-11-2019, 12:56 PM   #6
Chassis: TC1000 FE
Engine: 5.9
It's already at the landfill so I'm just gonna have to deal with it or buy another one lol.
Old 12-11-2019, 02:59 PM   #7
I've driven a bus without heat in winter. I looked like FDR with a blanket on my lap. Was MISERABLE.
Shaking, jaw clenching, it was just pure COLD.
Old 12-12-2019, 10:10 AM   #8
Chassis: TC1000 FE
Engine: 5.9
such will be my lot!
Old 12-12-2019, 11:04 AM   #9
Good luck. That trip made me very hesitant to wanna do anything like that ever again.
Old 12-12-2019, 11:37 AM   #10
Coachwork: Blue-Bird
Chassis: TC RE 3408
@lebusmagique, you can replace your foot warmer with this: WR4000 - Products - Aqua-Hot Hydronic Heating
The only problem is that it needs 3/4 inch hose. I have been unable to find even a single new heater with one inch hose. Most manufacturers make only heaters with 5/8ths hose. I have found 2 retailers so far that have a few heaters with 3/4ths inch hoses.
Aqua-Hot makes a total of 4 models that come with 3/4 inch hoses. The one I linked above is the smallest. The others go up to 30,000 BTUs. But I have concerns about Aqua-Hot. They want you to prurchase by phone and I don't normally give out my phone number, especially to retailers. Retailers normally get a disposible email.
Aside from Aqua-Hot, all I have found so far is that Fisheries Supply has one heater made by Red Dot that is available in both 5/8ths and 3/4ths. There are several other Red Hot heaters listed on Fisheries Supply, but all the others come only in 5/8ths hose size.
https://www.fisheriessupply.com/red-...00-btu-150-cfm
I have already removed both heaters from my passenger compartment. I intend to replace them with one after market heater. I would like to replace both the front heaters too, just because they are 25 years old now. I will continue my search for heaters with one inch coolant connections, but I am not very optimistic about finding any. If anyone could point me to a source I would be very grateful.
gs1949 is offline   Reply With Quote
