Old 08-12-2022, 03:47 PM   #1
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
Rated Cap: 40 passenger
Plastic on Bluebird Bus steering column
Help, any idea what kind of plastic this thimble is made of?
I’m going to patch/repair it, and I can do a better job if I know what material it is.
It is an injection molded part. Black plastic.
Does anyone happen to know?
The second pic is of the rubber boot that goes over it.
91D423E1-5714-47CE-BF3C-4084C02C5312.jpg   EE25C771-C1AC-4398-916C-A08E97B00874.jpg
ChurchBuz is offline   Reply With Quote
Old 08-13-2022, 10:59 AM   #2
Dbacks2k4's Avatar
Year: 2006
Chassis: IC CE300 (PB105)
No idea on the plastic type, but if it were me I'd call a bluebird dealer with your Vin and get the part number, then search ebay for new old stock. Might be easier and cheaper to get a replacement than try to repair that one.
Unless of course, you're more into the adventure of the project... in which case, just tune me out
Edit - getting original part number may allow you to research it and get insight into the material from manufacturer?
TSLABUS Build thread:
https://www.skoolie.net/forums/f11/j...ert-38328.html
TSLABUS YouTube Channel:
https://youtube.com/@thetslabus
Dbacks2k4 is offline   Reply With Quote
Old 08-13-2022, 11:23 AM   #3
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
It looks like you would have to remove the steering column to change it. I'd be inclined to maybe try a little ABS cement on it first. It's a solvent type adhesive so it will either work well or not at all.
Rwnielsen is offline   Reply With Quote
Old 08-16-2022, 11:45 AM   #4
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
Thanks guys: I would have had to do a ton of work to replace it.
I used a JBWeld plastic putty. I put wax paper down and filled in what was missing.
Couple drawbacs:
white instead of black, and you can see part of it.
Some of one of the parts was hardened and made mixing difficult.
Gets all over your hands. Wear gloves!
Otherwise it worked like a champ.
Heads up: because I only access this forum through my phone, it limits my ability to thank, and like.
Know this: I am glad when people take the time to reply. Consider yourself thanked! And liked!
Old 08-16-2022, 12:59 PM   #5
Rwnielsen's Avatar
Rated Cap: U/K
The first step in using any adhesive, tar, cement, paint etc. is to first smear some on your pants and shirt. It saves time.
Old 08-21-2022, 05:23 PM   #6
JB Weld is paintable, and for plastic SEM plastic dye is outstanding. Clean well with 91 percent rubbing alcohol before applying, and many very light coats is better than a heavier coat. I used this on plastic speaker parts to color match to a car, and the parts I did not use went into my nuts and bolts bin. After a few years of abuse in the bin from searching out nuts and bolts, the dye never came off.
Veloc is offline   Reply With Quote
Old 08-21-2022, 06:04 PM   #7
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
Great to know!
Thank you!
