Old 07-15-2020, 11:38 PM   #1
Year: 2008
Coachwork: gmc
Chassis: 3500
prison bus cages - Where to find?
I'm looking to install a prison bus cage as a partition behind the driver seat. Any idea where I might find one in the NorthEast? used? pretty hard to comeby online
also looking for some school bus window cages
unitybuilder is offline   Reply With Quote
Old 07-16-2020, 07:38 AM   #2
I just spent about a month fabricating a wall like this, starting here in my build thread: https://www.skoolie.net/forums/f11/r...tml#post387303
I'm gonna be kinda mad if you actually find something like this pre-made.
Old 07-16-2020, 11:43 AM   #3
UFO pilot's Avatar
Year: 1963
Chassis: HPO
Engine: Cummins 220
Rated Cap: 1
If your project is a 3500 Chevy like in your profile you have either a van or a van cutaway front end, probably a box truck. Look for a "cargo partition" or "security gate" from a private seller or salvage yard that takes in commercial vehicles.
YMMVClick image for larger version
UFO pilot is offline   Reply With Quote
Old 08-01-2020, 12:26 AM   #4
Year: 2008
Coachwork: gmc
Chassis: 3500
thank you very much. For some reason, I had it in my mind that I had to have the cage in the "bus" part of the build and not the "van" front. hence the looking for the prison cage. I wanted the cage to be in back of the passenger seat that I put in. Something about putting my fiance on the other side of a cage bothered me. I'll go with it though.
Old 08-01-2020, 12:27 AM   #5
Year: 2008
Coachwork: gmc
Chassis: 3500
love the build. I have zero skills with building with metal. It looks great though
Old 08-01-2020, 06:54 AM   #6
I also had zero fabricating skills when I bought my bus. A skoolie (especially a badly rusted one) is a great opportunity to learn, though. These pre-built security cages can probably be had relatively cheaply, but the materials for my wall were only about $150 (the expanded steel sheet was most of that; the windows were free).
You could also build a partition wall with 2x4s, which would be a lot cheaper and easier. If you're planning to insulate the wall, it would be the same thickness anyway.
Old 08-01-2020, 11:18 AM   #7
Chassis: chevy
Engine: 3116 catapillar
rob a bank then ask your prison bus driver
mmoore6856 is offline   Reply With Quote
bulkhead, cage, divider, partition, security
