Old 02-19-2020, 04:02 PM   #1
Engine: Cummins 8.3
Rated Cap: 25
Propane heater for radiant floor
I am looking for inexpensive battery powered propane heater for my radiant floor system. I am planning to have a pex solar heater on the roof so would like to have the propane one just in case the temp. would drops below let’s say a hundred degrees. I was thinking about Marey 5L model but just received a message from their tech support saying that the incoming water should be cold, otherwise it would damage the rubber diaphragm on the inlet valve. 100F is definitely not cold so I am looking for alternative recommendations.
Elmix is offline   Reply With Quote
