Old 01-16-2018, 12:25 AM   #21
Rated Cap: 37,400 lbs GVWR
Now if they made a low floor FE that would be ideal.
I've seen some ugly low-floor FE shuttle-type buses at the local Seizure World near here - I don't know what make they are, but with some imagination it could have a rear ramp to ride a bike straight inside. Anything's possible.
Old 01-16-2018, 12:37 AM   #22
We are getting away from the original Skoolie theme going in that direction.
Old 01-16-2018, 05:24 AM   #23
It sucks having a lowrider bus.
Old 01-16-2018, 05:24 AM   #24
Not everyone here has a school bus. Or even a bus at all.
Old 01-16-2018, 06:41 AM   #25
joeblack5's Avatar
Year: 98
Thanks Pepito for your link, very inspiring. I will follow a similar procedure.
later J
Old 01-16-2018, 06:53 AM   #26
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Originally Posted by joeblack5 View Post
I think JD installed some electric floor heat.
Yep, Johan is right. My write up is here: Bathroom Heated Tile Floor - JdFinley.com However; I haven't yet finished the wiring/powered it up. So, no actual experience to report.
I'm having to dig several months back into the grey matter but IIRC, the issues for me were...
1. Ceiling height. I don't have a lot and increasing the floor "thickness" to accommodate water lines was a problem. I thought about installing the lines under the floor (via the basement) but that was not going to be easy or quick.
2. I was worried about leaks over time (as Tango noted). Especially given my propensity to drill a hole or insert a screw before thinking.
3. .... something else... I can't remember what it was but I know there was another factor...
It seems to me that electric is used to 'heat the floor' whereas hydronic is used to 'heat the room'. Big difference. I think I would love a diesel/electric fired hydronic system cause it is a wonderful feeling heat (at least it is in a S&B home) but I just couldn't justify it in the bus.
JD - Full timer out west
My Adventures & Build
Old 01-16-2018, 10:51 AM   #27
I can see underfloor hydronic used as a "room" heater. I would imagine the floor would have to be pretty hot in order to heat the room. I believe both systems are intended to heat the floor. I'm wondering how each system would perform if it's under a subfloor and top floor. I would think it would be most efficient if it was directly under the top floor, which means it would be imbedded in the rigid foam directly under the top floor.
