01-02-2020, 01:11 AM
#141
Chassis: fs65
Engine: 7.2 catapillar 3126
Rated Cap: 41 students
I'm glad I found this thread. I'm a new bus owner and I had been thinking about this topic for a while even before.
My only thoughts are that I would rather leave the inner ceiling panel and whatever insulation is in there be, then install furring strip on each rib, then ADD spray foam or rigid foam, then screw my finishing panel to the furring strip. Essentially ending with layer that look like this from top to bottom :
Outer metal
Insulation (assuming it has some)
Inner metal panel
Furring strip and spray foam or rigid foam
Finishing panel (solid sheet or T&G)
In this scenario I have to believe I'll get better insulation this way, rather than having removed the stock inner metal panel and insulation, and then adding new insulation and a new finishing panel.
Plus my reasoning is time saved in not removing the oem bits.
Height inside is not an issue.
And lastly for what it's worth. I plan on leaving the stock floor as well and insulation and adding new flooring on top. Also for better thermal dynamics.
Thoughts? (other than weight or time or price) specifically asking for insulative properties.
Thanks
01-02-2020, 03:16 AM
#142
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Originally Posted by WIbluebird
Wish I could re use my ceiling metal but unfortunately it's the perforated variety that Bluebird offered as a premium "acoustic" ceiling.
Can you see thru it when you sre standing close by. If you can then you may be able to sell it or use it to make screen doors for burglar bar door/gates.
01-02-2020, 04:47 AM
#143
All busses are different.. my 3.. my carpenter I can feel the interior ceiling get hot as soon as the sun comes out.. so I know the factory insulation is worthless.. if I were converting it I’d want to pull the ceiling ..
My bluebird which came with factory AirCon is insulated pretty good, that bus ceiling takes a good long time to get hot when sun hits it. I might be inclined to leave it if I converted and was not travelling to extremes..
My old 78 superior I’m not sure there’s much insulation at all..
Of course winter isn’t the time to do a “sun test” of your ceiling but point is all busses appear different I’m how well they were done at factory..
Floors - if you have plywood and a perfectly tight sealed bus there’s a chance the floor is in good shape otherwise most I’ve seen are harboring mold and creating rust where the wood got water logged from leaky windows hatches etc.
I’d want to pull the rubber and at least take a look.
Christopher
01-02-2020, 06:36 AM
#144
Rated Cap: me + 1
Outer metal
Inner metal panel
Thanks
Ceiling plan sounds good, not sure about the floor, I don't know how to do a non destructive test on it. Perhaps test the windows for leaks with a sprinkler running against it for a long while or try to mimic a hard down ward rain with hose - spray up and let it fall down at an angle while some one watches inside?? Maybe take the wall panels off and check for rust or signs of leaking. If the windows are leaking badly, the floor may have problems as well.
If the floor feels soft anywhere I would take it up and find out why. Might try the old wood rot/termite test, take an ice pick and start poking from both the top and bottom. If it goes in easy, you have problems.
one thought on the floor. OSB is not that expensive. If you ever go to sell the bus having photographic evidence that the floor is sound would be a good thing. If it is bad now would be the time to fix it. Take plenty of detail pics either way to document your case.
01-02-2020, 11:02 AM
#145
It is basically impossible to tell what is underneath the floor of a bus until you pull it up. I had a piece of ¾ plywood in the drivers section it looked fine from the top, when I pulled it up. it was full of nasty mold and decay underneath. I have heard lots of similar stories.
Looking for leaks can also be tough, most of my leaks were from the bottom corners of the windows. They were leaking and the water was going down the insides of the walls. I had the opportunity to stay in my bus when it was gutted for a few weeks in rain and snow melt. I got to see where all the leaks were.
I would not use OSB in a bus. OSB is designed for inexpensive/cheap interior grade use. Any water on it and it will deteriorate fast.. it swells and turns to a handful of wafer chips. In a home OSB is covered by tile or linoleum near sinks, in bedrooms it is covered enough carpet foam to handle a beverage spill. I have seen lots of OSB pieces out in 10-20min of light rain showers the next day it is ruined.
01-02-2020, 11:11 AM
#146
There's exterior grade osb.
But I'd still go with plywood. Marine grade if you're spendy.
01-02-2020, 11:58 AM
#147
Year: 93
Coachwork: Corbiel
Rated Cap: 36 pass
If you have a roof vent, unscrew the trim from the inside and have a look for insulation.
01-02-2020, 02:13 PM
#148
The "exterior grade" OSB has a thin coating on one side of it. It is designed so when you are building a subfloor or roof sheathing it can withstand rain a time or two before you get it covered. The coating doesn't last very long or withstand much it is only designed for exposure during construction.
I have seem homes being built that ran out of money or were neglected for a a couple of months. Even in a dry climate after a month or two of exposure the OSB will turn gray and start falling apart.
01-02-2020, 02:30 PM
#149
My house was built with such exterior grade OSB... they built the foundation for the basement.. put up the trusses, layed the floor with exterior OSB and started on the walls.. ran out of lumber.. (that was the year 4 hurricanes hit florida.. so ohio wasnt getting any lumber!).. was also one of the rainiest years oin record.. after 3 weeks of my house sitting in the rain the edges were curling up on thast exterior board.. yeah when we finally got lumber again, the few walls were torn down and floor pulled and re-done... it didnt last...
01-02-2020, 06:01 PM
#150
Rated Cap: me + 1
Thanks for the input on leaking.
About the OSB.
Most of my experience with OSB has been with roof decking. I was a diehard plywood fan because that was all I had ever used and OSB reminded me of particle board and that crap would swell and fall apart when wet.
Then one day I needed some quick disposable side boards for one of my pickups to enlarge the capacity to haul wood shingles to the dump (lightweight but takes up a lot of space). The sideboards got left on the truck during a 3 say rain and I thought that I would have to trash them.... but they were still sturdy, the edges had swollen up but the were still use able, This prompted me to research OSB and try it out. Turned out to be better than OCX (decking grade plywood). Once installed, after exposed to a rain, OCX would bubble up (small delaminated areas on the top ply caused by the wood swelling/expanding when it got wet.) OSB did not have this problem. Both external OCX plywood, and OSB use waterproof glue.
The biggest advantage of OSB is in waste (this is not going to be true for school bus floors since the sheet is not spanning joists/rafters but is being supported by the flat metal floor). OSB is unidirectional (it does not have a grain and has the same strength in all directions). Construction plywood is stronger in the length direction than in the width direction and needs to be laid longways across spans (this is due to the number and direction of the plys). If you run it parallel to the spans it will sag when you walk on it. This means that it is hard to find a use for some odd shaped pieces on a job. It does not matter which direction you lay OSB so the odd pieces are easier to use up, less waste. OSB is also cheaper, not as cheap as it used to be now that it is so popular.
10-29-2021, 06:24 PM
#151
Putting original ceiling panels back up
We have been going back and forth on this  so we punched most of the rivets and took some off then tried taking down a panel. We have a 1990 International and our ceiling panels didn't fall right off like everyone we see doing this, our ceilings panels are thick!!! So after trying to remove one we notice that the insulation is in great condition and now we are backing out and going to put the panel back and keep the original ceiling but the screws aren't working so now we are planning on buying a rivet gun and putting new rivets in  so one thing is we pulled out the wiring for the speakers and lights our wiring was running along the ceiling, is this a typical thing in school buses? if so what doe people do to hide those wires? I think our ceilings may be steal and not aluminum.
10-29-2021, 10:00 PM
#152
They're steel. 20ga.
11-02-2021, 03:13 PM
#153
ok so we are feeling that its too late to go backwards because we already punched all the rivets and started pulling the ceiling panels down, now there is a a challenge coming up with this steel strip above the windows that seem to be holding the ceiling and roof in place, has anybody else had this in their bus? for anyone reading this in the future if you have steel ceilings in your bus I would recommend just leaving them alone
