Old 03-27-2023, 10:34 AM   #1
Quick Question On Sizing
Hey friends, I am headed to buy the square tubing for framing my RV windows in the hat channels.
My options here are:
1/16” thick 1.5” square tubing
1/8” thick 1.5” square tubing
1/16” thick 2” square tubing
1/8” thick 2” square tubing
Please help me decide. Thank you!
Nick5272 is offline   Reply With Quote
Old 03-27-2023, 10:50 AM   #2
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Funny, but none of those sizes seem to match what I use most. I'm not sure what you mean by "framing windows in the hat channels" so let me tell you what I usually find. I find that 1" (I get thick wall) square tube fits inside lots of hat channels. But for other framing, I seem to use a lot of 1.25" square tube. And sometimes, 1.5" inch. It all depends upon the existing wall thickness, which I need to measure on each bus. I've never found one that needs 2", though.
Old 03-27-2023, 12:24 PM   #3
That’s very helpful. I’ll bring a hat channel extension with me to the metal yard today and see what seems like it may fit
Old 03-27-2023, 12:53 PM   #4
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
For framing around windows, like RV windows, I don't use hat channel. I use square tube. I am admittedly not clear on your plan, but for lots of buses I've done the window framing was 1.25" square tube
Old 03-27-2023, 01:33 PM   #5
This is what I’m thinking except I’ll extend it all the way to butt up against the next hat channel and be welded or bolted there
https://imgur.com/a/Afgwghj
Old 03-27-2023, 06:37 PM   #6
Seems like you would want material that was the same thickness as the hat channel. If I'm not mistaken, Blue Bird hat channel is 2" deep so 2" square tubing would work best. The strength difference between 1/8" and 1/16" will be pretty irrelevant but the 1/8" thick tubing would be easier to weld without burning through the material; 1/16" would of course be cheaper (especially since you already have it, going by your reddit post).
Remember to wear a respirator when welding galvanized (or even when welding non-galvanized).
framing, roof raise, rv windows, tubing
