Rated Cap: 37,400 lbs GVWR
Just bear in mind what will happen when the new sheet metal gets hot in the summer and expands. Sheet aluminum, as long as it's not too thin, won't ripple as much as thin steel, but aluminum has twice the coefficient of thermal expansion as steel, so neither choice is ideal! Some converters heat up the new sheet metal with propane heaters before riveting it in place. I used 0.080"-thick 6061 aluminum to cover the two windows on each side that I removed, but I attached it with 3M 5200 marine adhesive/sealant that's flexible enough to allow some slight expansion/contraction. So far, so good!
