Old 07-18-2018, 08:02 PM   #41
01ThomasMVP's Avatar
Chassis: Thomas MVP
Engine: CAT 3126
Alright got the first 10ft section done. Got 4 more to do. I definitely reccomend the savogran superstrip paint stripper. The paint started melting off! That stuff will burn tho! Dangerous stuff use ur PPE. Got a tiny little splash on my arm and it was worse than getting hot metal shavings from grinding. Click image for larger version
01ThomasMVP is offline   Reply With Quote
Old 07-18-2018, 08:04 PM   #42
thrifty1's Avatar
Engine: DTA360
Looks great man good decision
thrifty1 is offline   Reply With Quote
Old 07-18-2018, 08:04 PM   #43
Chassis: Thomas MVP
Engine: CAT 3126
Dont u dare!Click image for larger version
Old 07-18-2018, 08:30 PM   #44
Does Coke taste better to you than Coke?
I like Crystal Pepsi.
Old 07-18-2018, 08:32 PM   #45
I knew you would. I don't drink Coke, I drink Pepsi.
Old 07-18-2018, 08:37 PM   #46
thrifty1's Avatar
Engine: DTA360
I drink Jack Daniels...
Old 07-18-2018, 08:38 PM   #47
I had this the other day and am going to finish off a bottle with a friend friday.
Old 07-23-2018, 01:24 PM   #48
davisdesigns's Avatar
Originally Posted by Tango View Post
Personally...I won't apply anything that contains water to bare metal, regardless of any product claims. Only oil or epoxy based. After that, you can go directly to final finish..or...if more build up is beneficial, use a high build primer...then the final.
Don't use epoxy unless you are 1. going to apply your top coat within 7 days or 2. plan on re applying epoxy before paint.
Real epoxy primer is not sandable and has not chemical bond after 7 days so your paint won't stick to it unless you re apply the primer.
I just primed using a DTM (direct to metal) primer, Urethane/ epoxy mix that is sandable. The brand I went with is SEM "metalock" its a 2k 4:1:1 primer:hardener:thinner
I don't think you will have any luck "sanding" that Henry's off, I me pretty sure you can steam it and use a putty knife though.
The bigger issue i see is you using sheet metal screws, replace them with pop rivets and you won't be giving people flat tires... A cheap pneumatic rivet gun can be had from Hearbougher fright and will keep you from getting carpal tunnel or the dreaded "claw" and after 960 rivets my hand feels fine
davisdesigns is offline   Reply With Quote
Old 07-23-2018, 02:19 PM   #49
Chassis: Thomas MVP
Engine: CAT 3126
Just finished the second coat. I sprayed on the OSPHO stuff with a spray bottle and let it set for over 24 hours. I sanded it down as smooth as I could but there was still some drippage showing that I was hoping the paint would cover. You can still kinda see them and it isn't the best paint job but I think it looks alright, I'm no pro but at least the rust is gone and the metal is covered. I'm gonna have to hope that since we put a bunch of caulking under every screw, they aren't gonna go anywhere. Otherwise if we start noticing them disappearing we will have to get them switched out. Click image for larger version
ID:	24364Click image for larger version
ID:	24365Click image for larger version
ID:	24366Click image for larger version
ID:	24367Click image for larger version
ID:	24368Click image for larger version
Old 07-23-2018, 02:24 PM   #50
Looks good to me.
Old 07-23-2018, 06:52 PM   #51
thrifty1's Avatar
Engine: DTA360
Awesome man. Love that you did the right thing
Old 07-23-2018, 07:17 PM   #52
Chassis: Thomas MVP
Engine: CAT 3126
Yeah thank you guys a bunch for the help! I'm gonna continue showing my progress on my main thread. Next up for me is to install my RV windows and it'll finally be weather proofed. Then it's time for insulation!
Old 07-23-2018, 08:25 PM   #53
I drink PoP! not Soda
Old 07-23-2018, 09:34 PM   #54
"Pepsi makes me burp!"
-- Redd Foxx
