Originally Posted by Brewmaster
Hello All,
Just wondering, I'm reading to build my rear bed crossways on my short bus. I've seen that everyone is using either wood slats or plywood below their box spring or mattress. I have a metal bed frame with springs and metal chains stretched between it and was thinking of using that simply because it would be so much lighter. Any reason no one else isn't using the metal frame ?? Just wondering !!!
Your on-hand frame is probably one of the best frames to use. No boxspring required? If it's the type I'm picturing, the springs allow the mattress to breathe, helping to will away moisture from the occupant.
Older Steel bedframes are made from spring steel, & they retain their shape well. For this same reason, the angle iron frames are also terrific for fabricating tank/battery supports, beneath the conversion.
