Old 06-03-2021, 06:13 AM   #21
Rock-N-Ruth's Avatar
Chassis: Amtrans
Engine: 444E
Rated Cap: 84 pas
Originally Posted by Daybreakbus View Post
In order for my insurance on my skoolie to kick in, I need to send them a picture with all of the seats out of the bus. But, I need to do that before I can drive it off of the lot. So in order to save time I figured I'd just saw through the legs with a reciprocating saw(rather than unscrew all of them on the lot before I drive it home. And then once it's home I can tackle the screws and get the feet off. But my question is, have any links to any sawa that are reasonably priced and will cut through the legs pretty quickly?
If you go with progressive commercial for private use policy you wont need to remove seats. I have two buses insured through progressive for 402.00 per year
Not each. That's 201 per year each. However if you are bent on removing the seats, baring rust, two guys can do it in less than 2 hours. One guy can do it in about three hours. Even faster if you use a cordless drill to turn the socket on the underside.
If one guy is doing the job use a box end wrench and gorilla tape to hold it on the top. Then crawl underneath and hit it with the socket.
Seats have lots of valuable plywood and useable metal in them.
Rock-N-Ruth is offline   Reply With Quote
Old 06-03-2021, 08:20 AM   #22
Year: 2005
Chassis: Thomas (37 ft)
Originally Posted by DeMac View Post
In what state, are you seeking insurance? Damon Pritty, State Farm Agent, is a skoolie owner. Fill out the user profile. It helps us help you.
That's amazing!! I'll look him up thank you
Daybreakbus is offline   Reply With Quote
Old 06-03-2021, 11:51 PM   #23
Grind the tops of the bolts off.
Removed seats in a couple hours
Cheers
Dirtdoctor is offline   Reply With Quote
Old 06-04-2021, 07:44 AM   #24
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
if you are going to have a generator onboard after done buy it now and you can skip the cordless and save unnecessary tools you will not need in the future.
mmoore6856 is offline   Reply With Quote
Old 06-04-2021, 04:10 PM   #25
Engine: C7 Cat
Good call figure out what genny you're going to use and get it now.
And a good lock! And storage insurance.
Cheers
Oscar1 is offline   Reply With Quote
Old 06-04-2021, 06:01 PM   #26
Agreed, however I have spent enough time tripping over power cords and extension cords to somewhat regret not getting at least a few battery-powered tools. I've done a lot using my two drills at the same time and their cords always end up May-poling and driving me insane.
saw legs seats
