Old 10-24-2019, 12:04 PM   #1
Chassis: Integrated CE S
Resizing trailer hitch receiver
I came into a free (important point) trailer hitch receiver today and decided it was worth the gamble as I didn't have any measurements handy. Unfortunately, the receiver mounting is 42" on the inside and my frame is 34" at the mounting point. With that in mind, do I have any options with this hitch, or should I forget about trying to make it work?
Pictures for reference. Hitch:
Frame:
I was thinking my two options are to space 4" either side with square tubing or something and run bolts through + weld, or cut and reweld the receiver bar. Neither of these options actively excites me, but has anyone tried this or has any other ideas?
Build thread: https://www.skoolie.net/forums/f11/bus-down-by-the-river-26371.html
inhof009 is offline   Reply With Quote
Old 10-24-2019, 12:42 PM   #2
Pizote's Avatar
Coachwork: ICCORP
Chassis: CE300
Rated Cap: 16
If you know how to weld... cut the ends off get some steel and fabricate new brackets.
If you don’t know how to weld, take it to a fabricator and have them do it.
Follow my build - and adventures at https://www.facebook.com/pizote.adventures
Pizote is offline   Reply With Quote
Old 10-24-2019, 01:35 PM   #3
I do know HOW to weld, but I don't have a welder nor would I trust whatever I tow with my current skill level.
Fortunately, I do know a few welders who could help me.
Old 10-24-2019, 01:56 PM   #4
You can get new side plates from etrailer and get a welder to shorten it
Old 10-24-2019, 04:01 PM   #5
Take it to any welder and tell him you want it 34" overall, easy peazy. Shouldn't cost but $40. Make sure your measurement is accurate.
Old 10-24-2019, 05:34 PM   #6
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Hate to be a bearer of not so good news but, that pic of your undercarriage is scary!
Way too much rust on anything to try to weld a hitch onto.
I'd even be scared to try bolting anything to that without some serious de-scaling and close inspection of those rusty frame members.
Good Luck...
peteg59 is offline   Reply With Quote
Old 10-24-2019, 05:45 PM   #7
With those rails I would sandwich a plate on the back side if the rails still have integrity.
Old 10-26-2019, 01:13 PM   #8
Good Luck...
You are not at all the bearer of bad news! I'm well aware of the status back there. I've investigated and there is still plenty of structural support left in the frame members (for now), and it is in the plan to strip and re-treat. Whether I go for welding or bolting, the entire area will be cleaned prior to the hitch being attached.
Old 10-26-2019, 01:14 PM   #9
I'll reach out to my welder friends and a few fabricators and see what they think. Good to know it's feasible, thank you!
Old 10-26-2019, 01:20 PM   #10
They make kits where the end plates come separate and you cut the tube to length and weld on the plates that bolt to the frame rail. You will be doing the same thing. On my pickup I just welded the 2" crosstube to the frame rails.
