Originally Posted by Spodabee
Here's a pic of the bolts and the seams
Those look like the heads of carriage bolts, so you should be able to get underneath and undo the nuts without any assistance. An ordinary wrench and a hammer should get them started if they're corroded, and then a drill will get the nuts off quickly. If they're also welded, you're in for hell.
You should be able to sell these pieces for
a lot once they're out. Here's a link for this stuff new:
https://www.metalsdepot.com/steel-pr...el-floor-plate. Your stuff would be well over $100 new, could probably get at least $75 a sheet on CL or Facebook Marketplace.
If you're 5'11" in a 6' bus, you're definitely going to want all the headroom you can muster.
