Old 04-29-2021, 06:24 PM   #1
Chassis: Sfe T Liner
Rated Cap: 31,000
roof rack
I am starting my bus build. We have a 40' Bluebird. My question or rather idea is this. We want a patio on the roof. We don't know what all else. My thought is, put a tubing frame down both side of the bus that are equal height to the dome of the roof. This will be installed before redoing the roof. I plan to sandblast and finish the roof with silicone roofing. The roofing would go over the tubing on the racks. Later, anything you would want on the roof would be attached to the racks. They would run the full length of the bus. That would keep me from having to attach through the roof every time I want to add something up above, solar panels, storage, kayak racks, and so on. The racks would be welded on before the roofing product goes on.
Busnbuster is offline   Reply With Quote
Old 04-29-2021, 06:36 PM   #2
Preemptively installing racks is not a bad idea. You're probably not going to want to try welding them on, though. The roof is thin sheet metal riveted to the ribs of the bus, and you wouldn't want to weld supports to that sheet metal. The usual way is to bolt them through the ribs, which is a lot easier to do before you finish your ceiling inside.
