What area are you in? I could get you channel in central FL, but am super busy with some projects at the moment.
Im in IL so its a bit of a drive, but thanks. Maybe the coast is better but metal price is 3 times over what it usually is here, I've already got square tubes and some flat bars so I'm really hoping it will work out.
Cant seem to find anyone with pictures who had to shim up their tubes, though it is mentioned a few times.
I mean once you weld the two pieces together (correctly, that is) do they function about as good as would a single piece? Would you weld down the length of the shim/tube or would you drill and plug weld?
