Old 02-22-2022, 07:24 PM   #1
Roof raising short bus, sheet metal and joining cone
Hi all, I'm converting a 24ft short bus and am currently figuring out the process for the roof raise. I have two questions, first I have access to a bunch of what I believe is 24-26 gauge medium polish stainless sheet metal and am wondering if its too thin for siding. Second are there any guides for forming the join between the raised roof and the unraised part?
Umbra is offline   Reply With Quote
Old 02-22-2022, 08:19 PM   #2
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Hi, Umbra. Welcome to skoolie.net What kind of short bus are you raising?
Unless you going for the wrinkle look, I'd recommend 18-16 guage.
Old 02-22-2022, 08:59 PM   #3
1997 GMC Forward aka "Lego Bus"
https://www.instagram.com/p/CPMFQCSDs5P/
Old 02-22-2022, 09:11 PM   #4
I think its known as a lego bus
Old 02-22-2022, 09:26 PM   #5
DeMac's Avatar
Engine: 466ci
Rated Cap: 90
Sweet
Those are pretty cool. Not plain shelf vanilla. Is there space for a co-pilot, in front of the entry door?
Old 02-22-2022, 09:33 PM   #6
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Hi Umbra, for the joints I like to remove rub rails and hide the joints beneath those. And, it's important to run new sheet metal from joint location to joint location...so your 12 or 14" roof raise might actually need a sheet 24 inches tall (for example). You cannot just cut a line and count on it looking good. Here's a playlist of a roof raise, which might explain that better. https://www.youtube.com/playlist?lis...9pxqxRelSBl7uW
Old 02-22-2022, 10:15 PM   #7
Yeah once I remove the heater system there is room to put a co-pilot in there, I was playing with idea of putting my battery and electrical there.
