Old 10-28-2024, 11:29 AM   #1
Roofing Tar for window corners
Someone talk me out of using roofing tar for lower window corners.
wanderingturtl is offline   Reply With Quote
Old 10-28-2024, 02:05 PM   #2
Year: 2008
Coachwork: Thomas Built Buses
Chassis: Ford E-450 cutaway
Engine: 6.0 Power Stroke diesel
Rated Cap: GVWR 14,050
Um, just don't. There are a ton of options better than roofing tar IMO.
Use butyl rubber instead, or one of the many industrial weather-stripping tapes (I like the ZIP system tapes at HD and Lowes), or both.
Tar will probably seal for a bit, but it will also get warm, run, and drip.
Caulking sealant
https://www.amazon.com/gp/product/B003VARIII
Butyl strip (very sticky both sides - used for RV window installs and other)
https://www.amazon.com/Butyl-Black-T...dp/B07PW3W33M/
Butyl tape (sticky one side)
https://www.amazon.com/dp/B0CQF65YS5/?th=1
AlphaHare is offline   Reply With Quote
Old 11-02-2024, 08:15 PM   #3
Chassis: Thomas
Rated Cap: 8 seats, 5 wheelchairs
Don't do it
It's gonna run as it weathers and look nasty on a nice pain job.
1dmpo is offline   Reply With Quote
Old 11-02-2024, 09:53 PM   #4
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
What do you mean by the word "tar"? Tar is a generic term that is usually used to refer to bitumen, aka asphalt, or coal tar pitch, which is very brittle when solid. Both are hydrocarbons and will burn or melt at lower temps. I believe you actually are refering to plastic roofing cement which is asphalt + various additives mixed with a solvent and possibly fibers, to help prevent cracking and doesn't require heat to apply.
Reasons for not using it are.... it sucks to work with, is very difficult to seal metal with because metal expands and shrinks with temp changes much differently than the plastic cement which is not very flexible, doesn't play well with paint or caulks, cracks, and is a pain to remove. You need some type of flexible caulk to deal with aluminums high thermal coefficient of expansion. It helps if the caulk is paintable to conceal flaws
Old 11-03-2024, 11:33 AM   #5
Coachwork: Our hot little grubbies...
Rated Cap: Five Heelers
Instead of roofing tar on my windows, I think I would go with tin-foil.
Or rattle-can them.
Your choice of colors!
LargeMargeInBaja is offline   Reply With Quote
