Originally Posted by Lazyboxer
I have an 85 Thomas and the thin weather strip around the glass on side windows has shrunk. Any ideas?
Should I replace the rubber or is there an effective alternative?
Mostly one corner on each windo has "popped out" the rest is intact.
Thanks in advance!
Resealing the windows is not real hard to do just labor intensive.
All the windows that I removed from two busses so far get recycled for my sandblasting cabinets.
FREE GLAS...yeah!
Disassembling the aluminum frames is real easy except every once in a while you will find a stubborn screw or two. I just grind them off.
Point is that you can completely disassemble each window and re-seal with quality automotive window sealer.
