11-08-2022, 05:46 PM
RV water heater install location
Looking for input / insight from anyone who has installed an RV water heater (Girard, Fogatti, etc). From the videos I've seen folks will cut the square hole in the side of their bus and place the unit on their subfloor. However I don't want to cut the chair rail area so was thinking of building a box for the heater to sit on and then cut the hole above (see photo).
Is there anything I might be missing here? Its obviously stressful to cut such a big hole so want to make sure I get it right!
11-08-2022, 06:24 PM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Your plan looks/sounds just fine. I actually like that you're not cutting through the chair rail. Good planning!
11-08-2022, 07:10 PM
We installed ours just above the chair rail. Its sitting in the bottom of the base cabinet under the sink, and it just so happened to line up above the chair rail. Its pretty nerve wracking to cut a hole like that into the side of the bus, but ya gotta do what ya gotta do.
11-09-2022, 08:32 PM
I would STRONGLY suggest not cutting any holes until it's absolutely necessary to do so. You think you know where the heater is going, but if there's anything at all that you haven't taken into account on your build, any measurement that's off, or anything in the design changes for whatever reason, you might find that hole in the wrong place.
11-10-2022, 12:43 PM
Coachwork: Crown, integral
Rated Cap: 37,400 lbs GVWR
How about putting the water heater under the floor instead? If your bus has underfloor storage bays you can put it inside a bay, and to save precious storage space there you can then hang the heater from the floor above, still leaving space under it for storing Stuff. If you don't have underfloor bays, just hang it anyway from the floor. Advantages of doing this is that you're not using limited interior space, and if the heater should leak it will not flood the interior. I did this for my bus, and it now takes only a few minutes to easily remove the heater by simply loosening its four hangers, moving its support tray about an inch to the left and an inch down, then it just slides out. Easy!
11-12-2022, 07:10 PM
Chassis: MVP ER
That is where I put mine, just in front of the rear tire, on the passenger side. This will allow me the shortest length for the kitchen sink and the indoor shower. I had to cut the fender brace, as it was a tight fit due to having a 100 gal water aux water tank right next to it. I will rebace the fender and build a small frame on the backside to hold some insulation as I plan on a lot of cold weather camping.
11-16-2022, 04:51 PM
Year: 2005
Engine: 6.4 liter Mercedes MBE 900
Rated Cap: 48 passenger
I did what you are describing. Put the 6 gallon Suburban water heater on a box to raise it. I also DID cut the chair rail, to have the heater and all it's "stuff" fit under the countertop, and be able to intersect the rub rail the way I wanted on the outside.
Edit: looks like the picture didn't go through. I e never been able to post a picture on this forum.
11-16-2022, 05:18 PM
Year: 2005
Chassis: FC
Engine: Cat C-7
I went with a propane on demand unit. It takes little space a has 1 round hole to outside for combustion air and exhaust
11-16-2022, 05:30 PM
Engine: Cummins 5.9 common rail
Propane on demand hot water heater
My installation may not be for everyone but it works fine for me. Unlimited hot water for the kitchen sink and shower which is right behind the wall you see in the picture. The supply runs are very short which helps conserve water. The water heater cost about $100 and the picture was taken during the building process.
11-16-2022, 08:52 PM
This is exactly where I'm putting mine (just on the other side of the bus), above the sink on the wall between the sink and the shower.
11-17-2022, 10:40 AM
Chassis: Ford E450
Engine: V10 Gas
Same location for me. I attach the vent pipe to the heater and it exhausts out the little side window of my shuttle bus. Very short runs of Pex.
