Old 04-28-2022, 09:37 PM   #1
Year: 2006
Chassis: Front Engine
Engine: Cat C7
RV Windows - dual pane worth it?
Finalizing design requirements for RV windows (we ditched the stock windows), and am realizing there is a bit of a price gap between non-insulated and insulated dual pane RV windows.
I'd love the hive-mind's perspectives on:
  1. How much of a liability is a non-insulated RV window in a 4 season bus?
  2. (assuming they are necessary) Any hot leads on sourcing insulated windows of reasonable price/quality?
Thanks!
tomrasdf is offline   Reply With Quote
Old 04-28-2022, 10:01 PM   #2
My bus has all its original windows and I'm building insulated inserts to cover them all out of 2" XPS faced with plywood. Insulated dual-pane windows are better than single pane, but they're still far enough from real solid insulation that you'd probably want to cover them in really cold weather anyway, so in my mind they'd not be worth spending the extra money on.
Old 04-29-2022, 09:27 AM   #3
After years of camping in a Suburban and waking to condensation pouring down the inside of the windows I made sure I used dual pane windows in my little bus. The only window I get condensation on is the windshield--even with the use of a close fitting shade.
Old 04-29-2022, 03:40 PM   #4
Phantom5824's Avatar
Coachwork: Gillig
Chassis: Phantom 40'
Engine: DDECII 6V92T Allison MT647
Rated Cap: 37,400 lbs of potential
Nice. I will be watching this thread too. As ol trunt said, condensation is a real concern. In my opinion, for cold-weather use, insulated glass is the way to go.
I haven't yet found manufactured windows that suit me, so I am considering building my own insulated window units for my conversion.
Phantom5824 is offline   Reply With Quote
Old 04-30-2022, 08:37 AM   #5
Coachwork: Our hot little grubbies...
Rated Cap: Three RedHeelers
Originally Posted by tomrasdf View Post
...dual pane RV windows...necessary...
2003, for our ExpeditionVehicle, we mounted 3010 (three feet wide by a foot tall) dual-pane sliders designed for a stand-still house.
We mounted these at our eye-level standing inside, about eight feet above pavement.
a)
We thought the dual-pane would be resistant to temperature fluctuations, and somewhat mitigate noise transfer.
Real-world:
To vent humidity and odors, our windows are open 24/7/360°, so that eliminates one advantage.
b)
Second point... noise abatement:
Our walls are much bigger than our windows (structurally, I think this's a good idea).
Accordingly, we insulated with:
* adhesive-back acoustic against the wall, then
* one-inch pink-board, another air-gap, then
* two-inch foil-side poly.
You ask my experience.
We would do this again.
But, experience comes at a cost.
For about a half-century, we full-time lived-aboard a wide variety of conversions.
c)
We think yuge picture windows are impossible to insulate.
You could hang thick curtains to block some of the temperature transfer, but that eliminates the view... one of the purposes of a yuge window.
An aside:
We tend to be private people.
We treasure our solitude.
We like the ability to choose the time and the folk for our outside interactions.
Small windows set high help accomplish our goal.
A yuge picture window invites peepers to constantly investigate our inside activities.
And we think that is a bad idea.
d)
You ask about 'RV windows'.
We are pretty sure anything 'RV' has no place on a realistic conversion.
Based on our experience, anything from the 'RV industry' is barely adequate for cheap disposable RecreateVehicles designed by committee with only one consideration -- short-term profit at all costs.
If I wanted that, I would acquire that.
But, I do not, so I build and convert.
LargeMargeInBaja is offline   Reply With Quote
Old 04-30-2022, 11:12 AM   #6
Spent many hours searching for a window solution for my bus conversion which will get used in winter weather. Jeld Wen custom made to fit vinyl sliders with tempered glass added up to $361 each and several months wait time. Lowes house brand sliding windows (Reliabilt) in size 24X24 cost $98 and fit perfectly in this 03 Bluebird with some trimming of the nailing fin (and upper flange). I'm going to copy LargeMarge (Thanks man!)and mount them with flexible caulk.
Timeline is offline   Reply With Quote
Old 04-30-2022, 11:35 AM   #7
TheHubbardBus's Avatar
Coachwork: IC
Engine: t444e
Rated Cap: 24
Far less experience here, but that pretty much echoes my sentiments.
'Marine' is the word we use in most circumstances.
Welcome to Costco. I love you.
<< Our Build Thread >>
<< Beefy Bus on Instagram >>
Old 05-07-2022, 10:45 AM   #8
Year: 2006
Engine: Cat C7
Thanks all for the input!
Pursuing several paths right now including custom and 'marine' to get a good idea of options and relevant tradeoffs between $ / quality.
I'll post when we decide on a path forward.
Old 05-10-2022, 11:04 PM   #9
if you plan to full-time in Winter, dual pane windows will make life much better. How many people and pets will be living aboard? Do you have a shower? Propane stove? All of these factors seriously increase humidity in an RV.
BFlinn181 is offline   Reply With Quote
Old 05-11-2022, 06:43 AM   #10
Hello, I was curious if you might be willing to show a step by step on how you did the mod and install of these types of windows... I'm really digging this idea.
Thomas
TMartineau is offline   Reply With Quote
Old 05-11-2022, 09:45 AM   #11
Sorry Thomas haven't got any further than a test for size so far. Hope to get them in before winter, will post some photos of how it goes....
Old 05-13-2022, 09:26 PM   #12
Year: 2006
Engine: Cat C7
I'm looking hard at ordering residential dual-pane windows with tempered glass.
Any words of caution about taking this route?
Old 05-14-2022, 09:11 AM   #13
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Ol Trunt did that a few years ago. There's a post with all of the order info, even a copy of the HomeDepot order form. Tempered Dual Pane Shed windows. Seems like they've been holding up over the years.
Frederick Douglass: "If there is no struggle, there is no progress. Those who profess to favor freedom, and yet depreciate agitation, are men who want crops without plowing up the ground.”
Old 05-14-2022, 09:20 AM   #14
Here's the original Home Depot order form. If you type in Shed windows in the Skoolie search engine at the top of the page you'll get more info.
http://www.skoolie.net/forums/f11/ho...ows-36517.html
Old 05-14-2022, 09:42 AM   #15
Year: 2006
Engine: Cat C7
I’ve been cautioned by several well meaning tradesmen in residential construction that using residential tempered glass in a road-going application may cause some sort of rift in the space time continuum resulting in death, destruction, and denied insurance claims.
Not your experience?
Old 05-14-2022, 10:09 AM   #16
Bouncing and banging down the road may break the seal and result in fog between the panes. The windows I bought will collect a lot of dust in the drain area, which will be a chore to keep clean especially on dirt roads....
Old 05-14-2022, 07:03 PM   #17
Order the extra strength tempered glass variety. It meets the same standards as regular tempered windows used in cars. Do not use non tempered glass for obvious reasons.
