Old 01-05-2016, 06:27 PM   #1
Engine: 7.3L Diesel
Question safety features preventing engine from starting????
My bus won't start, but I believe it has something to do with one or more of the safety features. The bus ran like a top for the three hour drive home, then I've started it twice in the month since it's been here. The last time I tried to start it it made a buzzer noise and wouldn't start until I finally realized the back door had to be closed as a safety feature (then it started right up again with no trouble). Now this time it's making the same buzzer noise but won't start even with the door closed. I've been doing a bunch of research and probably don't know the terminology to get to the bottom of this, but I suspect others on the board will understand (I hope!) What else might I be doing wrong?
Are these safety features something that I can disable whenever I get to removing all the unnecessary wiring?
Thanks bunches!
Jamie
jwilcox is offline   Reply With Quote
Old 01-05-2016, 06:55 PM   #2
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
Are you in neutral?
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 01-05-2016, 06:57 PM   #3
opus's Avatar
Chassis: All-American R/E
Open emergency window, hatch?
Old 01-05-2016, 09:26 PM   #4
Engine: GMC
Rated Cap: 42
Did you lock the back door? Some buses won't start with the backdoor open and they won't start if the backdoor is locked.
JA Savage is offline   Reply With Quote
Old 01-05-2016, 11:23 PM   #5
charles_m's Avatar
Year: 1982
I want to make a dice set for diagnosing these kind of problems and keep them in the dashboard.
Some Ideas for Each Side:
In neutral
Rear door locked
Dead battery
Bad solenoid
Bad starter
Rear start/ignition switches (rear engine buses)
thats enough ideas to cover a cube!
www.bustoshow.org
Old 01-06-2016, 03:35 PM   #6
Engine: 7.3L Diesel
I guess it was in reverse yesterday! It started right up when I changed the gears. The shifter is a bit hard to read but that seems to make sense. Thank you all again.
Old 01-06-2016, 06:26 PM   #7
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Old 01-06-2016, 06:30 PM   #8
Engine: 7.3L Diesel
Well, I pretty new to this, so I'm not so hard on myself :-0
Basically, I drove it home and have done research to start the renovation project. Feels pretty good so far! But I couldn't do this without the great help from this board!
Old 01-06-2016, 11:30 PM   #9
charles_m's Avatar
Year: 1982
well, at least thats the best thing to have wrong! congrats
www.bustoshow.org
Old 05-29-2023, 11:41 PM   #10
Did something similar
I have my bus parked at a storage place so I lock it up at night in between being here and not. Today after figuring out how to remove all of the adhesive I decided to start the bus and same buzzer noise you described and no start condition. So I couldn’t wrap my brain around what was so obvious to be an emergency exit issue. I thought I was at a loss until I read your solution then I realized I needed to go to the back of the bus and slide the lock back into it’s fully opened position. Went to the front and good ole Bertha started right up.
Douneedhelp is offline   Reply With Quote
engine, safety, starting
