Old 12-04-2019, 03:15 PM   #1
Rated Cap: 71
Sanding/Treating rivetheads before Seam Sealer
Hey Everyone. I am planning to put some seam sealer down on top of the roof at the joints and rivet lines but I was wondering if it is necessary to sand down or convert the rust on the rivet heads before putting down seam sealer?
After that we are going to lay down our Henry’s roof paint!
For the Henry’s application, does the current white roof paint need to be sanded down to metal or just roughed up a little bit?
Thanks all!
AF0A81A6-F8DA-465A-9DCE-8ACB3E7FF1C7.jpg   80CBB12E-F6DB-457C-A44C-18A74CD7FB12.jpg
rydawg3000 is offline   Reply With Quote
Old 12-04-2019, 05:08 PM   #2
Chassis: Blue Bird
Engine: ISC 8.3
If you want any coating to stick to those rusty rivet heads they'll have to be cleaned up. Wire brush at least (I'm thinking a wire wheel or cup brush in an angle grinder or maybe a drill, actually). It's hard to clean a rivet head by any means except media blasting because the head is domed and it's down in a dimpled depression in the metal. Brush to remove loose stuff followed by an acid converter might work; I haven't tried that.
As to removing the white paint: I think it depends on how well the existing paint is bonded. On my bus the roof paint was peeling off the primer. Big spots were missing, but the metal hadn't rusted because the primer was intact. I sandblasted the whole roof, and while doing it, sometimes saw chunks of paint as big as a quarter breaking off. If your paint is still bonded well then a simple wash, degrease, and scuff may be all you need.
Old 12-04-2019, 05:14 PM   #3
wire brush on a drill will knock out that rust on em. But then you'll need to sand a bit then paint.
Old 12-04-2019, 08:19 PM   #4
Rated Cap: 71
Thanks familywagon and EastCoastCB!
Awesome, I’ve been wanting to use a cup brush on something! I’ll try one out with my angle grinder or drill.
Our paint is in very good condition on top, no peeling or chipping of any kind so that’s good news. For the degrease, should we use acetone or mineral spirits or denatured alcohol or something else?
Old 12-04-2019, 08:21 PM   #5
Rated Cap: 71
Also, super lucky to doing the build in Florida so we can do projects like painting and spray foam even during the winter!
Old 12-04-2019, 11:25 PM   #6
tugboater's Avatar
Chassis: Saf T Liner MVP 11 window 32’
Engine: CAT 3126E
Thanks all!
Probably a good idea to clean those up before coating. Our factory seams didn't leak (only my own did), but looked just like yours. I dug out the old sealer as best i could then laid a couple beads of new stuff. After it cured I rolled a strip of Flex Seal over them. We still need to paint the roof, but when the time comes we'll use a marine maintenance enamel for that.
One...slow...step...at a time.
tugboater is offline   Reply With Quote
Old 12-05-2019, 06:19 AM   #7
Yep. Sure is nice here.
Old 12-05-2019, 06:38 AM   #8
The rivets on the back of my bus were all rusted pretty severely. I removed the paint from all of them and the skin around them with a painter's tool, then treated them with Ospho a few times, cleaned and painted with POR-15 (which adheres extremely well to post-osphoed pitted metal).
Old 03-27-2020, 12:26 PM   #9
Chassis: TC1000 FE
Engine: 5.9
Attachment 39811
Uhhh was this Flex Seal Liquid? I saw this post and thought "hey that's a good idea!"
Did it last night and realized today it can't be painted over.........
I'm so screwed.
lebusmagique is offline   Reply With Quote
Old 03-27-2020, 06:07 PM   #10
I'm so screwed.
Heh, had a couple seconds of "hey, some guy on reddit just did the same thing!"
Old 03-27-2020, 07:40 PM   #11
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
You're not alone!
JDSquared is offline   Reply With Quote
Old 03-28-2020, 10:19 AM   #12
Chassis: TC1000 FE
Engine: 5.9
Yep that's me. I managed to get it all off thankfully. Just used my pressure washer and peeled the paint off with it. That's what I get. Curious about what this guy's plan is though? Is he going to do his whole roof in the flex seal?
Old 03-29-2020, 02:55 AM   #13
We used EternaBond to seal the seams. That stuff works well. Comes in 4" wide and 6" wide rolls.
Old 03-29-2020, 11:50 AM   #14
Can you get SUPER specific on which product you used -- looks like EternaBond comes in 100 flavors!
Did you then paint over the eternabond tape? (assuming you've painted your roof white for TX/FL living...)
David
The Murder Bus
Old 03-29-2020, 07:10 PM   #15
EternaBond RSW450 (4 inch wide) and RSW650 (6 inch wide). In some places I split the RSW650 down the middle to make 3 inch wide strips. After that I rolled 3 coats of Ames Maximum Stretch Elastomeric Roof Coating with Hi-Tech ceramic beads added into the elastomeric paint. The result is a tough coating that is similar to Rhino coating. It does not stay real clean due to the ceramic beads. It does wash off fairly easily.
Old 03-29-2020, 07:17 PM   #16
Note: I had to remove a lot of silicone caulk as neight the EternaBond nor the Ames elastomeric paint will stick to silicone,
rivet heads, rust, seam sealer
