Old 07-11-2021, 02:13 PM   #1
Engine: dt466e
"School bus" lettering
How did you guys go about removing them without the yellow paint ripping and coming off with the letters? Feel i might have to do something extra when it comes to finally painting my skoolie because of this
adic27 is offline   Reply With Quote
Old 07-11-2021, 02:23 PM   #2
I used a heat gun and a putty knife, followed with lacquer thinner and scotch brite. Others swear by the eraser wheels you can pick up at auto paint suppliers
Danjo is online now   Reply With Quote
Old 07-11-2021, 02:57 PM   #3
Engine: dt466e
Forgot to mention I used exactly that, heat gun and puddy knife. Some letters came off smooth on the other side and here and there but no matter how much heat I let hit it what you see in the pic happens.
Thanks!
Old 07-11-2021, 02:59 PM   #4
flattracker's Avatar
Engine: Cummins 350 big cam
Rated Cap: 86 passengers?
I used a razor scraper to remove the lettering on the "new Crown" as they were stick-on letters. I used an orbital sander to touch up the paint surface and then painted over that. The old Crown has painted lettering so probably will use orbital sander for that.
flattracker is offline   Reply With Quote
Old 07-11-2021, 03:00 PM   #5
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Everything, Danjo suggested, yes.
Yours may need heat. (I see you tried heat)
Probably use multiple methods, depends on the decal. The plastic blades worked well on all of my reflective tape & bulkheads. Used the PinForce wheel on most black lettering. Mineral spirits & acetone worked on the glue, but slow. Xylene works better. Replaced plastic blade frequently.
Frederick Douglass:
"A man is worked upon by what he works on. He may carve out his circumstances, but his circumstances will carve him out as well."
Old 07-11-2021, 05:30 PM   #6
Thanks!
Too much heat? Well, anyway, you’ll just need to fill that back in with primer and sand back to level. Not really too bad
Old 07-11-2021, 06:52 PM   #7
I don't think I've ever seen school bus lettering peel off the paint behind it - it suggests that maybe the entire bus paint job did not adhere very well to that galvanized material. What happens if you take the heat gun and putty knife to an area that was not underneath lettering?
Maybe they applied the lettering before the paint had completely cured, and that caused adhesion problems only underneath the letters?
Old 07-11-2021, 08:23 PM   #8
Get a Whizzy Wheel...basically what DeMac has in his photo, above. I've had success with those when heat and scraping failed to remove things, without paint damage. The Whizzy Wheel won't damage the paint beneath.
Old 07-11-2021, 11:20 PM   #9
Engine: C7 Cat
Heat gun, razor scraper and acitone on a rag is all I've every needed.
(Wear gloves when using acitone)
Good luck
Oscar1 is offline   Reply With Quote
Old 07-30-2021, 05:40 AM   #10
Chassis: TS2000 FE
Rated Cap: 67
I used one of these. Worked fantastic. Kinda peeved I messed up the paint on a few letters before I found it.
https://www.amazon.com/Adhesive-Remo.../dp/B0922LTMNC
MountainJeff is offline   Reply With Quote
Old 08-08-2021, 07:29 PM   #11
Coachwork: Michael Corbier
Chassis: GMC Savana 350
Engine: 6.5 Diesel
Whizzy Wheel
I used this product on the school system lettering on all sides of the bus. I recommend it. I also used goof-off to remove the adhesive.
Corbi is offline   Reply With Quote
Old 08-18-2021, 05:12 AM   #12
Year: ‘09
Chassis: Vision
Engine: 6.7
Rated Cap: 35’
Hot pressure washer. Blows them right off, and the paint too if you are too close. Enough practice and you will find the perfect distance. It makes a mess, but I have tried all of the other ways, and this is the fastest with the least amount of paint loss.
Ranchorossa is offline   Reply With Quote
