Old 11-09-2019, 02:57 PM   #1
Seat belt malfunction?
Hey Everyone,
As I am prepping to drive the bus 70+ miles to the foam insulation installer.
One of the things that are needed is making my drivers seat-belt functional again.
While demoing I unbolted the top seat belt mounting plate. Now I need to reinstall it. AS I am trying to do the the "lockup" mechanism is misbehaving.
The spool that allows you to gently pull out the seat belt and stop any rapid movement of the belt.
Well, the seat belt in here worked perfectly until I unbolted the bracket so that I could complete demo.
Now I am trying to put it back together and having trouble.
The spool locks up even if I attempt to gently and slowly pull belt from the spool. I have backfed belt to try and get it to release. all I have accomplished is to wind the spool to its max capacity.
Any suggestions?
Thanks.
S.
Old 11-09-2019, 05:34 PM   #2
Have you tried this?
Old 11-10-2019, 03:11 PM   #3
Originally Posted by Danjo View Post
Thank you for the video.
Unfortunately, I tried it and was not successful.
Old 11-10-2019, 03:32 PM   #4
Is there a way you can access the pawl? Move it out of the gear with a screwdriver?
Old 11-10-2019, 03:40 PM   #5
I tried removing the covers long enough that I was about ready to try using a hammer. It was time to step away
I will give it another shot and see how it plays.
Thank you for your suggestions. Much appreciated.
Old 11-10-2019, 07:50 PM   #6
Send a pic. Any identification on it?
Old 11-10-2019, 08:34 PM   #7
The re-tractor lock-up feature responds to more than g-force. If you held it off angle from how it was installed on the bus it will not unlock -- the retractor will "think" it was in a rollover accident.
Keep searching youtube to you find a video that matches the type belt you're working on. You may have to destroy some plastic rivets for access but you can replace them with a sheet metal screw upon reassembly
Old 11-10-2019, 10:58 PM   #8
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
I guess I got lucky. I had similar issues when I pulled mine and started to panic but i was able to gently rock/wiggle it around until it released. Good luck!
peakbus is offline   Reply With Quote
Old 11-11-2019, 01:46 AM   #9
Bon Voyage's Avatar
Rated Cap: 81
I had the same problem and ended up taking apart the belt and couldn’t get it back together again. I’m pretty sure that I just didn’t have the angle right so like mentioned above the belt was locked thinking it was in a roll over accident. Spend some time playing with the angle it is at before you do anything drastic kind I did.
Bon Voyage is offline   Reply With Quote
Old 01-08-2020, 09:37 AM   #10
Engine: Cummins 5.9 24v
Rated Cap: 54 passenger
Did you ever figure this out? I knew not to because of the specific post, but I went and did it anyway.
JDSquared is offline   Reply With Quote
Old 01-12-2020, 06:09 AM   #11
My attempt to disassemble if proved fatal. I wound up ordered a new one from Amazon.
Good luck.
Old 01-12-2020, 09:42 AM   #12
Good luck.
Sorry. I got mine fixed. I didn't think I had any room to pull left but I pulled it a tiny bit, and nothing. I pulled harder and got more, like a quarter inch, and it loosened.
Old 01-12-2020, 11:07 AM   #13
Glad you had better luck than I did.
I fed a little belt back into the housing then pulled gently over and over until there was no room on the feel. Then I tried to open the housing to access the pawls and see what I could do. In the process of disassembley it kerdploded.
Old 01-12-2020, 11:38 AM   #14
Coachwork: Amtran RE
Chassis: International 3000
Engine: T444e 7.3L
I need a replacement driver's seat belt - I accidentally set the old one on fire.
I'm thinking about heading to the junkyard, but I'm curious what other folks did for replacements. There are a few in Amazon, but they don't have good descriptions or many reviews.
Biscuitsjam is offline   Reply With Quote
