Originally Posted by cofrari
I had the idea of adding a second fresh water tank to the roof of the bus which would only be tied into the Hot Water on the shower. My thought is that in the warmer months, the sun would warm the water to a high enough level to where it would be satisfactory for the shower without the need to use the hot water heater. For the cooler months, I would have a way to switch the hot water back to the main fresh water tank in which case it would run through the propane powered hot water heater.
My only thought is that I should use a clear tank for the roof to prevent any kind of mold to grow (seems like a clear tank would reduce any chance of that happening). I would need a second pump of course. I can get a 20-gallon tank that is only 4 inches high, so I don't think it would add a whole lot of wind resistance. And I'm probably looking at about 250 pounds of weight. And this would only be for the shower - not for any type of internal consumption.
Is there anything I missing with this idea?
Probably won't add materially to the roll of the bus, if you're only talking that kind of weight; and I doubt you'd hear the water slop around up there (where it will be knocked about more than tanks closer to the ground).
I don't know if you want to have unprotected clear plastic up there-somewhat at risk of damage I would think.
As an alternative I've seen youtube videos of folks using 4" diameter ABS (black plastic) pipe in a loop. You'd only need three sticks (30') to get the same volume. It's pretty cheap, very durable and heats up via solar.
Check those videos out for some ideas.
