Old 06-16-2022, 04:35 PM   #1
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
Rated Cap: 40 passenger
Service Ramps
I built some service ramps out of some super heavy aluminum angle that I got at scrap price. They are about 17 1/2” wide, 14” tall, and 6 ft long. There are also two separate 14”x 17 1/2” x 24” platforms for the wheels to rest on.
Will post pics.
They are real heavy, but they have to hold up a heavy bus, so….
ChurchBuz is offline   Reply With Quote
Old 06-16-2022, 04:39 PM   #2
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
Service Ramp Pics
With my friend Jeff
FA616CB3-86E1-4BFB-B610-496B1A05383B.jpg   7D036C3E-DCF2-4B9B-AA50-4FCFE61DBCAD.jpeg
Old 06-16-2022, 04:44 PM   #3
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
The set up gets the bus way up! And when centered on the platforms the ramps can be removed.
Hope I never need to pull the transmission out, but if I do, these ramps would sure help.
With the flat front, the approach angle is a little close for clearance. Scraped a little. But it appears that if I pin up my mud flaps, I can back up the ramps with no interference.
Heads up: because I only access this forum through my phone, it limits my ability to thank, and like.
Know this: I am glad when people take the time to reply. Consider yourself thanked! And liked!
Old 06-16-2022, 04:51 PM   #4
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
I had them done a few weeks now, but I was not going to try them out without a spotter.
Once up on the platforms that last step out the door is a doozie!
I ran around hastily taking some pictures, because Jeff needed to leave already, and I neglected to measure the height of the bottom of the back door to the ground.
My guesstimate is that it dropped about 12”. But I will probably remember to check next time.
The door
Old 06-16-2022, 04:55 PM   #5
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
i know that definitely helps work on it.
maybe a piece of 2x12 at the tails of the ramp to pick it up just enough that it doesnt rub going up.
looks good
Old 06-16-2022, 05:08 PM   #6
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
looks good
I had thought about putting something at the start, and it might work, but the fewer pieces the safer. Backing up them instead of going forward, is not going to be any more difficult or sketchy. I’m not going to do it without a spotter anyway.
My fear keeps me pretty safe (all considered).
Old 06-16-2022, 05:12 PM   #7
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
looks good
Thank you!
Old 06-16-2022, 09:14 PM   #8
I made some similar ramps to level my bus in its parking spot (my spot is on a downward slope where the front tires are about a foot below the rear ones) but out of layered pressure-treated lumber. I'm sure these are way lighter than mine. My biggest fear is that someday I'm going to forget I'm up on them and drive forward.
Old 06-17-2022, 05:14 AM   #9
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
Thank you for your reply.
Yes, I know the fear of driving off the end!
I am planning a set of stops, if possible.
Your ramps may be heavy, but these are heavier than I would like. Combined they weigh 258lbs. I’m glad that is divided up into 4 pieces.
Old 06-17-2022, 01:04 PM   #10
fo4imtippin's Avatar
Chassis: TC2000 28ft
I have a set of plastic ones that say they handle 12,000lbs on both (not total vehicle). I have almost 9000lb on my front axle, im thinking of testing them. Wonder if they pancake.
Old 06-17-2022, 03:21 PM   #11
Old 06-17-2022, 05:27 PM   #12
ChurchBuz's Avatar
Year: 91
Engine: 6-BT
It is one thing if you are leveling a vehicle, it is another if you are climbing under it.
I suppose it also depends on how high they lift. I might be inclined to test them if the bus doesn’t drop too far and mess something up on the way down.
They usually build a safety margin into stuff like that,
