RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 02-18-2021, 08:46 PM   #1
Engine: dt466e
Shapeable aluminum material
Anyone know what I can use for/to create a 47x47 inch cheap drain pan for a pop up camp shower? Something I can add a drain to, even if it's a simple whole with pvc pipe into a 5 gallon bucket. Imagine one of those big aluminum foil pans you bake a lot of food in. Something like that but maybe like an inch to an inch and a half and of course 47x47 inches
Thanks
Edit: something like this would be perfect but 47x47 inches..
https://www.lowes.com/pd/CAMCO-Washi...B&gclsrc=aw.ds
adic27 is offline   Reply With Quote
Old 02-18-2021, 09:05 PM   #2
Chassis: G30
Engine: 350 Chevy
Probably have to custom make that. 47x47 is not exactly common, and an aluminum foil pan would not do the job. Maybe you were simply using that as an example?
Anyhoo, good luck. A custom pan made in that size from 1/8"or 3/16" aluminum shouldn't cost too much to have made?
Old 02-18-2021, 09:06 PM   #3
You added an extra "http://" in front of your link so it doesn't work.
Old 02-18-2021, 09:08 PM   #4
Engine: dt466e
I posted a link of a better example and probably better option but didn't do it right. It's fixed now.
Old 02-18-2021, 09:08 PM   #5
Engine: dt466e
I know, sorry. Just fixed it
Old 02-18-2021, 09:10 PM   #6
Chassis: G30
Engine: 350 Chevy
A house water heater usually has something like that under it as well. Might be round shaped?
Don't know what sizes are available though...
