Originally Posted by ejboyed
Okay so I have found some new options with the CAT3126 and have made some calls. Thoughts on whether a MD3060 or AT2000 or AT25000 is best? Also could you give me some pointers on what to check out next on the bus? I know to check for rust and tires are pricey if old but what are the next things to be on the look out for?
3060 is best, but the 2000 is a fine transmission as well. The 3060 is the heavier duty of the two and has an extra OD that some have had success at unlocking.
One haggle point is tire condition. How old are they? There are DOT codes on the tires that will tell you the age.
