Old 04-05-2021, 12:31 PM   #1
Titania's Avatar
Year: 2006
Engine: Cat 7
Side Door Emergency Exit Leak Fixes
Hi there friends! Happy Monday, lol.
So, our floor is almost all prepped to have the actual flooring over it. The only problem is we can't lay down something until everything is sealed. Our side door emergency exit basically doesn't exist when it rains because there is just a huge spray of water every time it rains.
I've seen adding trim, weather stripping and seam sealers, but what do ya'll think?
Thanks so much!
Titania is offline   Reply With Quote
Old 04-05-2021, 01:10 PM   #2
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
Can you take a picture of the outside top of the door and the door jam with the door open.
This will get you more valid feedback.
On my bus, my gutters do a great job.
Old 04-05-2021, 03:23 PM   #3
My side door is kind of a mystery. It has never leaked except one time in a driving rain when water was pouring down the inside of the door. I have a pic of this in my build thread or I would think I had just lost my mind and imagined it. I have some theories about where the water is coming from but my leak theories usually turn out to be wrong.
What shape is the door gasket in? You can replace those and/or add additional weatherstripping on the frame where the gasket presses in to get a better seal. You can also modify the extended arms on the three-point latch so that they pull the door in tighter against the frame.
Or it may be the window in the door leaking? Or the ceiling above the door?
Old 04-06-2021, 04:12 PM   #4
Titania's Avatar
Year: 2006
Engine: Cat 7
Thank you both for replying! Pictures would help wouldn't it hahaha!
So the actual trim is fine, it's actually super clean and looks brand new. I saw Musigenesis' post and I was like... y'know, that's a good point, maybe it just isn't tight enough or lining up.
The entire top area where there aren't hinges have the trims lining up with it, there's a huge gap. Should I add more/bring the door tighter in?
Also ignore the handle, it rusted off, the rest of the bus is in great condition, I swear!! Hahaha.
Old 04-06-2021, 05:43 PM   #5
My handles were similarly rusted, so I cut them off and riveted steel sheet over the openings. In all likelihood you won't ever need to open these doors from the outside (unless you're using them as entrances) and a lock that isn't there can't be picked; the latches will still work from the inside.
Old 04-07-2021, 12:02 AM   #6
Simplicity's Avatar
I can't see anything obvious.
Let's try to recreate the problem.
Shut the door. Assure it's snug. If it isn't snug, determine why and address the issue.
Make sure the windows on both sides of the door are closed.
Lay a garden hose on the roof so water drains from the top of the roof and down both sides of the bus, enough that the windows on each side of the door have water going over them.
Go inside and see if you can find the leak. It may be in the roof and running down to the side by the door and dripping.
Once you find a drip, hose off, fix drip.
Good luck.
Steve
Old 04-16-2021, 04:45 PM   #7
Titania's Avatar
Year: 2006
Engine: Cat 7
Belated hello!!!
Thank you so much, this gives me such peace of mind haha.
Good luck.
Thank you so much for this! I ended up waiting so long to where it rained, and we discovered that our gutter system has a bit of a gap in between the body and the gutter. This was letting in all the rain and dripping it directly in from above.
I guess we could just either silicone it or flex seal it? Hahaha.
Old 04-16-2021, 06:59 PM   #8
Chassis: Blue Bird TC2000
Engine: Cummins 24V 5.9/ Allison 2500
Don’t use silicone! I know it seems logical, and we started out with silicone for some of our leak fixes as well. But, as we learned, silicone will lead to rust because it holds moisture against the metal. After learning that, we switched to using 3M Dynatron 550 ($15 per tube at Autozone) with good results. Ive heard a product called Sikaflex is good also.
Ourversionoflife3 is offline   Reply With Quote
Old 04-16-2021, 07:14 PM   #9
Simplicity's Avatar
There's a reason why the gutter is separating. Don't just fill the gap. Inspect and discover what the problem is, fix the problem, clean out any debris or old sealant and then seal with a quality weather PROOF sealant/adhesive.
Sikaflex is a good product. They make many types of adhesives, sealers, etc.. Do some research.
After you've properly repaired and sealed the gap, you're going to want to seal the entire roof with an elastic sealant like
https://www.zoro.com/henry-5-gal-whi...0aAoigEALw_wcB
If you seal the roof first, test it for any leaks, you'll be more assured to continue with the inside conversion. Don't worry if you need to drill or cut into the roof later, because you can always apply more of the coating over any additions/repairs.
Steve
Old 04-17-2021, 03:07 PM   #10
Titania's Avatar
Year: 2006
Engine: Cat 7
Ah thank you so much! I'll look into both and try them out. I really appreciate it!
Thank you very much!
leaky door, side emergency exit
