Old 07-12-2021, 11:08 AM   #1
Skoolie driver seat
Swapping my old brown seat for a newer one. Newer one is air ride and I have a few questions.
What is the best way to make this a swiveling seat? I bought a base thinking I'd chain based together, but it adds too much height and I think would hit the wall on swivel.
2nd, I forgot to check what the standard airline size is. I need to by a coupler to connect it to my old stop sign line.
Thanks!
krazykrivda is offline   Reply With Quote
Old 07-12-2021, 11:30 AM   #2
Chassis: International 1753
Engine: 6.9 International
They make seat base swivels for semi trucks. They're used to swivel toward the bunk side of the sleeper. Using one of those for your particular seat model would be the best way IMO. But, You'll likely hit the cabinet on the left side though, so you might have to move the base of the seat on the floor towards the rear.
Old 07-12-2021, 12:21 PM   #3
Like Booyah said...they do make them. Buy they're expensive and I've not found that our buses have enough clearance to rotate. They're designed to work next to a door which opens and no bus we have will accommodate one, because of the sidewall and panels on the left.
The seat air line should be 1/4 inch, if it's standard. While you're at it...stop at any truck stop and look in the trucker section for a seat air line blow nozzle. They come with a 1/4-inch tee and a coiled hose and an air nozzle, so you can blow dirt off the steps and such...super handy and pretty cheap.
Old 07-12-2021, 01:13 PM   #4
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
You can buy a whole bag of push to connect fittings on Amazon for a couple bucks...people complain they cause leaks but I've had good luck with mine. I forget what the standard size is but it's very easy.
Correct on the swivel, I bought one but quickly realized it doesn't work in a bus, no room for it to swing around. It now lives under my passenger captain's seat which sits far enough away from the sidewall to be useable.
Old 07-12-2021, 02:10 PM   #5
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
Air ride and swivels
I don’t think you are going to find an “off the shelf “ solution to your want. If you are not a handy person, find a place that builds race cars or off road race buggies.
I have RV seat swivel mounts, 7” high. I might have to make it shorter. I moved the pedals, steering column and seat to the left, so that I could fit a passenger seat up front and keep the bus doors. Lots of work.
William
Old 07-13-2021, 12:27 PM   #6
shaymcquaid's Avatar
Chassis: 40' MVP-ER
My seat is a National Seating cush-n-aire. The OEM swivel was $89.00 and works flawlessly. Great purchace
shaymcquaid is offline   Reply With Quote
Old 08-09-2021, 07:26 PM   #7
HamSkoolie's Avatar
Rated Cap: 31,800 pounds
I went to their website. No prices so that sucks. I don't do business with such folk.
We've done so much, for so long, with so little, that we can now do the impossible, overnight, with nothing.
The United States Marines, America's 911 force -- 6531, 3521 '79-'99
Retired mech (auto/aviation), Extra Class HAM, NAUI/PADI OpenWater
HamSkoolie is offline   Reply With Quote
Old 08-09-2021, 07:49 PM   #8
Since they are a manufacturer, you can't do retail business with them. You need to check pricing at their dealers.
Old 08-09-2021, 09:17 PM   #9
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
I was at the International dealer today (my bus is broken) and sat in the seats they have on display. Comfy!
The point has been made, there has to be enough room to swivel, yet more importantly, to square you up behind the wheel.
Like to see what you come up with.
Steve
Old 08-09-2021, 10:35 PM   #10
How much do they cost?
Old 08-10-2021, 06:56 AM   #11
WIbluebird's Avatar
Rated Cap: 75
Just check your local marketplace/craigslist for semi truck seats. Truckers throw those out all the time, often despite being brand new.
Old 08-10-2021, 08:26 AM   #12
That's where I got mine. 20 bucks for both the air ride driver and the solid mount passenger seat. The driver had some wear on the cushion, so I swapped the passenger seat's cushion over to the air ride base.
No idea why he replaced them, and I didn't ask. You can go mild to wild on truck seats, so I assume mine is a base model and he upgraded to something more luxurious.
We actually just swapped out a solid based passenger seat in a KW for an air ride unit. Cost was about 700 bucks, and we still have the old one that looks near new in the shop yet. I might see if I can repurpose it in the bus somehow.
Old 08-10-2021, 10:46 AM   #13
WIbluebird's Avatar
Rated Cap: 75
After seeing my local marketplace i would NEVER pay more than like $200 for an air ride seat. I scored mine for free and the guy even loaded it in my truck for me
We have lots of small companies and O/Os in my area that are always upgrading to super high end seats and throwing out the (still nice for a school bus) seats that come from the factory. I've even seen one still wrapped in the plastic from the factory That air lumbar support is so nice and the cushions and adjustments are all way better.
Old 08-10-2021, 12:08 PM   #14
Engine: C7 Cat
My passenger seat is from a smashed 2018 Kenworth, it is mounted 2.25" from the side wall and swivels in to the living space area. The no wall contact is achieved by siding the seat forward first. This seat has has air lumbar support and heat and was purchased from the wrecking yard complete with seat belt for under $400. This seat was built by Paccor and they do make a driver side swivel seat as well.image.jpg
Oscar1 is offline   Reply With Quote
Old 08-10-2021, 07:54 PM   #15
Chassis: Ford E450
Engine: V10 Gas
Thanks!
I opted not to change the driver's seat, yet. But even if, I can't see the merit in a swivel.
The passenger seat is definitely a swivel. I'm in the middle of that now, and there's no simple solution. Requires quite a bit of design, some welding, else pretty stiff money for a swivel base. And/or some combination of the above.
I bought a few van seats with integrated seat belts, then decided to go with a fully reclining van seat without the integrated seat belt that somebody left on the front porch. This is the current project on the bus and I'm slogging through it.
Old 08-10-2021, 08:28 PM   #16
What is the merit in even having the passenger seat swivel? For safety, you wouldn't want the seat to be facing any direction but straight ahead while driving. It would make the seat usable as general furniture while parked, I suppose, but do people really spend much time in the passenger seat while parked?
Old 08-10-2021, 08:49 PM   #17
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
The furniture helps create the activity bus, Musigenisis. Clearly, no activities happening on Rusty87.
Our bus can get so hot, no visible neighbors, minimal clothes. It's not surprising that most couples want rotating chairs, sturdy counters and stowaway beds. Active lifestyles.
How does it work in the hammock. Good tensile strength?
Frederick Douglass:
"A man is worked upon by what he works on. He may carve out his circumstances, but his circumstances will carve him out as well."
Old 08-10-2021, 10:31 PM   #18
HamSkoolie's Avatar
We plan a swivel passenger seat, right behind the stairwell with a drop down floor while underway. Swiveling 135 degrees to the left when parked will give another seat in the "living room" thus adding to the usability. The seat will be mounted on a custom welded and bolted frame secured to structural members of the bus to provide crash protection and three point restraint. Since that frame is being built from scratch it's no biggie to include a folding desk attachment so that one of us can sit in a very comfy chair while doing computer or other desk work.
We'll probably replace the seat itself for the driver but won't be swiveling it unless the floor plan undergoes unexpected changes. At the moment the idea is that when parked it will be the HAM radio station with HF/VHF/UHF capabilities as well as computer logging and all modes.
Old 08-11-2021, 01:42 AM   #19
Engine: C7 Cat
Everyone has different needs but being able to swivel the passenger seat in to the living space and facing the dinette works for us. Sounds like Ham and I are on the same page, cut down wheel arch and welded a frame then bolted through body cross members.
Cheers
Old 08-11-2021, 06:02 AM   #20
WIbluebird's Avatar
Rated Cap: 75
Yes, passenger seat should absolutely have swivel capabilities. It allows me to build a dinette behind it and then passengers can make use of the front living area better when it's parked.
Plus I travel with multiple people and it's nice for the copilot to be able to swing around and hang out with the people in back.
