Originally Posted by AXett
The question is, where can I source a replacement? The OEM is something stupid like $1500. I can't imagine a big square steel box is that pricey?........
WOW $1500 is crazey if it is just a standard tank. A few years back i bought a brand new 60 gal tank for like $250.it was a school bus spec tank if there really is such a thing. Many times the bus companies charge a BUNCH more cause its a "SCHOOL BUS PART" when it is really a truck part.
Making a bracket for a tank is super easy if you look under a late model C2 freightliner for ideas. (they have a rear tank between the frame rails if you make a plate that bolts to the bottom frame rails then Remove it and just make brackets and straps that hold the tank to the plate. )
