Thor industries most likely started with a Navistar cutaway chassisand then built the bus body. Best bet for bus systems is to contact Thor Industries. For the Chassis (engine, drive train, fuel tank, front cab, etc.) the chassis cab info from Navistar.
After the military i worked on (and later drove) a small fleet of buses built on Ford E350 chassis cabs. We used the standard info for a chassis cab E350 and the lift manual from the lift manufacturer. The bus "manual" was pretty weak and had little info.
You may be in a similar situation.
