Old 02-22-2020, 11:28 AM   #1
stlthe's Avatar
Chassis: Saf-T-Liner MVP EF
Engine: Cat C7
Rated Cap: 29 (Perimeter Seating)
stupid floor question, probably
ive gotten all the floor up, painted the metal and am going to start putting foam and plywood down soon. i didnt
there are lots of small holes in the floor where the seats came out.
do these have to be patched/filled, or would a blob of caulk/adhesive under the foam suffice to keep water out?
a few have been patched with jb putty, but there are quite a few left, and i'm feeling overwhelmed.
i know there are threads about flooring... i'm trying to cheat and make an already exhausting process a little less so.
thanks
evan
stlthe is offline   Reply With Quote
Old 02-22-2020, 12:24 PM   #2
Use a penny with some epoxy
Old 02-22-2020, 12:50 PM   #3
I opted to just epoxy + fiberglass over those holes, I made an extensive post about the process here. Long story short, just use two part epoxy for the small ones, with a thickening agent if necessary (or a penny!), and for the larger holes, like those for the lights on the sides, use cloth or even better spare sheet metal that hopefully you saved from the demolition. I've abused the epoxy/fiberglass combo for everything on the bus--if it's leaking, or needs a stronger seal, or I suspect it looks a little flimsy--I'll just reinforce it with fiberglass. There's better and prettier ways to do it for sure.
TheArgobus is offline   Reply With Quote
Old 02-22-2020, 02:28 PM   #4
stlthe's Avatar
Engine: Cat C7
thanks.
i had read about pennies here roughly a hundred times (recently). i've been so focussed on specific priorities its currency was in one eye and out the other!
evan
