I'm having the same issue, minus the 251 code, but plus 224 and 615 KAM related codes.
IDM power is present, lines all ring out clean, no corrosion.
Cleaned up all grounds
Batteries are good
Swapped idm's with one from a ford, no change
Beginning to wonder about the ECM...
The cart is old, the horse is slow, if you can pass, then go man go!
