Originally Posted by Willie_McCoy
Rucker, what are you using for a tankless LP heater?
Camplux 10L 2.64 GPM High Capacity Propane Tankless Water Heater, White. Cost about $280, runs on 110 (very low amp usage). I did not want the double D battery version of this heater.
I've picked up a recirculating pump, and have to decide whether to put it in. I might wait and see how it works first. The thinking is I can add hot water capacity with a holding tank if needed, to keep the instant heater from cycling on and off.
I have a propane tank enclosure, vented, and just run the water heater off the barbecue-style tank.
I mounted the heater inside and it vents through one of the little slide windows in the shuttle bus. Open the window and pop out the vent, it's ready to go. When done, stow the vent, close the window. No wall or roof penetrations.
I was going to run it on a separate, 500W inverter so I could turn off the 2Kwatt inverter for eco-mode, but I'm still figuring out how auto-transfer of shore power and battery will work.
