Old 08-08-2020, 05:26 PM   #1
lewirj's Avatar
Chassis: TC-1000
TC1000 front brake retrofit/rebuild
We've been on the road in our TC1000 BB for just over a year now. 9500 miles with no real issues. Michigan to Oregon, up and down the coast and back to Michigan.
I wanted to replace the front rotors (cracked completely thru) and pads but found that BB did not have the original rotors which are a one piece rotor/hub assembly. The only option was a retrofit "kit" that BB used to upgrade the TC1000 caliper bracket, caliper, hub, rotor, and bearings. It's an expensive but doable job.
With hope of saving others the headache I am listing the parts needed for the upgrade and a pic of the BB invoice. With luck you can source these separately saving $$$ and time.
Part name Manufacturer Part#
Webb Hub 25681--0
Bosch Caliper bracket 4153248
Caliper 4153269
Webb Rotor 54771P-65
Webb Rotor Bolts 85612
Spicer Dust Shield 974706
SKF Bearing Seal 35066
SKF Hub Cap 1326
Inside Bearing HM212049
Outside Bearing 3782Q
lewirj is offline   Reply With Quote
