Old 04-25-2020, 12:08 PM   #1
Coachwork: Freightliner/Thomas FS65
Engine: Cat C7
The alarm won’t stop! Help!
I bought a 2004 Freightliner/Thomas FS65 72 passenger bus yesterday. When the ignition switch is in the off position and the doors are open, the interior lights cut on and the horn won’t stop blowing. How do we stop it?!
cmstrick654 is offline   Reply With Quote
Old 04-25-2020, 12:34 PM   #2
Do you have a vandal lock? This would be a small lock on the outside, usually above and to the right of the passenger door (takes a separate key than the ignition).
Old 04-25-2020, 01:36 PM   #3
Could be a "Leave No Child Behind" alarm. When we were looking at buses at a Midwest Transit lot they told us we could start them up (but not drive them). I started a few. One of them, when I shut it off, had the horn alarm that you're describing. I walked away whistling when I couldn't figure out how to shut it down.
A maintenance worker came by and fixed it, and explained to me that there's a switch or button in the back of the bus that you need to hit after you shut the bus off. This feature is to make sure the driver walks the length of the bus to make sure no kids have been left on the bus. I don't know the details or the process, but it could be the issue you're having.
Old 04-25-2020, 03:12 PM   #4
Engine: C7 Cat
I agree that’s most likely what’s going on right now.
On my Thomas the reset button is right beside the rear door latch side. Be very careful if you attempt to disable the alarm in the fuse panel as you may cause a no start issue. I was able to disable mine but just can’t remember exact procedure right now. Will try and have a look at it again and see if I can help.
Oscar1 is offline   Reply With Quote
Old 04-25-2020, 08:25 PM   #5
Engine: Cat C7
That would be really helpful. Thank you.
Old 04-25-2020, 08:53 PM   #6
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Sad world we live in when this sort of thing is needed on a school bus... Not that I haven't seen it before.
Name:	Popcorn Sutton - Two Laps - Cheerio.jpg
Old 04-26-2020, 01:39 AM   #7
Call Freightliner Custom Chassis Corporation in Gaffney, SC with your VIN handy.
They may be reached at 800-385-4357.
This is the Freightliner help number ... very handy to have if your bus does not start too. This is the company that made your bus. They can also send you schematics and even your bus floorplan. They might even be able to set up a login to the DTNA site and the TBB portal so you can get information at any time.
Old 05-01-2020, 10:10 AM   #8
Engine: Cat C7
I appreciate that Native
Old 01-22-2021, 01:22 PM   #9
Year: 2010
Did you by any chance look to see how you disabled this feature? We thought we had disabled ours, but I just turned the bus on a d now each time I try removing the key the horn honking and light flashing starts. Any assistance you could provide would be GREATLY appreciated.
sue.sheffer@gmail.co is offline   Reply With Quote
Old 01-22-2021, 07:45 PM   #10
Year: 2008
Coachwork: IC
Chassis: IC CE300
Engine: Maxxforce DT
Because I triggered the "no child left behind" several times on my bus (IC CE300) without being able to cancel it despite following the sequence in the owner's manual (everytime had to disconnect/reconnect the batteries), I got the feature permanently disconnected at an International dealership (pretty cheap $33), because I could not figure out the wiring on the bus panel clear enough to attempt any disconnect myself.
Seb1 is offline   Reply With Quote
Old 01-22-2021, 11:54 PM   #11
Engine: C7 Cat
Sorry for the delay in replying. When I picked up my bus from auction the alarm for the no kid left behind was screaming non stop even when the button was pushed. For the trip home I unplugged the alarm unit complete(white clip under unit) and a second alarm that was plugged it to the flasher relay slot( see pic) this stopped the screaming without any affect on my ignition. I have not traced the issue any further than that. Hope this helps a bit.
Good luck. Click image for larger version
Old 01-23-2021, 06:07 PM   #12
Year: 2010
Thank you for the information. Friday I just opened the electrical panel and unplugged anything that showed in the diagram as being for emergency exits and emergency exit buzzer. If I can't get it to start again I'll take it to an international shop.
Old 01-23-2021, 06:13 PM   #13
Year: 2010
Good luck. Attachment 53337
Thank you, that is exactly what I ended up doing yesterday when I couldn't get it to stop. I haven't tried restarting the bus since then. I had just been out doing some work during my lunch hour. And today it was down in the 20's too cold to do any work on it.
Old 01-27-2021, 12:59 PM   #14
puh thanks guys, saved my day!
James42 is offline   Reply With Quote
