12-16-2021, 12:17 PM
Year: 2006
Chassis: MVP-EF
Engine: Cat C7 + Allison 3000PTS
Thomas bus - how to attach "window delete" panels?
For all those Thomas owners out there, did you do any window "deletes"? If so, how did you do them? On my 2006 it looks like the window unit is about 1-1/8" thick, and because it's just "clamped" in on the sides I can't really just put a piece of sheet metal inside the window void, nor can I put one on the outside because of all the bends in the bus frame. I'm thinking of using a piece of metal with some sort of frame on the inside so I can just clamp it down like a regular window, thoughts?
12-16-2021, 02:19 PM
Chassis: TC2000 28ft
Open to other suggestions as i need to do this as well. But i plan to use sheetmetal glued to XPS Foamboard or PVC Sheets glued to XPS Foamboard.
12-16-2021, 08:05 PM
Chassis: 31 ft. HDX
Engine: CAT C7 250 hp
Rated Cap: 36,300 GVW
My plan is to have sheet metal "plugs" that would have a formed edge to replicate the dimensions of the removed window assembly. Basically it would have an edge bent up all the way around that is the thickness of the window. On the inside I'm thinking about a sound mat stuck to the metal and then rigid foam insulation.
If you want the window back you could just swap it back.
12-16-2021, 08:08 PM
Year: 2006
Chassis: MVP-EF
Yeah that’s the only way you could fit a panel into the factory window voids…basically curling the sides up and over to replicate a sort of U channel.
I saw some pictures on facebook today that reminded me to work smarter, not harder. I think I can still just skin over the outside of the window if I remove and replace the screws between the windows, cut corners at the top to fit around the sheet metal body bends, and get sheet metal that can slip underneath the existing rain gutter just a tad.
12-17-2021, 12:54 PM
Coachwork: Collins
Chassis: NB18FD Oshkosh
Rated Cap: 18,500
What kind of structure is under that screwed on trim between the windows?
Myself. I would have a panel flanged on the top side. Notch the upper flange to go around any structure members between the windows. Leave the bottom edge a straight cut. Use that black trim piece under the windows as a line to hide with. I would use a panel bonding adhesive to secure everything. That leaves the panel with no screws to buckle the panel.
12-17-2021, 01:46 PM
Year: 2006
Chassis: MVP-EF
I had the same thought about a flanged (at the top) panel. Had not heard of panel bonding adhesives… I had figured I’d just use dynatron 550 behind the panel (to “glue” it on) and around the edges of the panel (to seal it), then maybe pop in some blind rivets along the edges? But I had also figured I would cut the panel to cover those existing screws between the windows so I could back out the screws, install the panel, then reinstall the screws to help hold it down.
12-17-2021, 01:54 PM
Yes, smarter not harder. I know, I did a roof raise by myself...never again!
A simpler way ? no cutting corners.
12-17-2021, 01:56 PM
Year: 2006
Chassis: MVP-EF
A simpler way ? no cutting corners.[/QUOTE]
That’s awesome! I didn’t realize those vertical pieces were just covers, I thought they were more structural.
(EDITed my reply to get rid of a dumb question once I reread the message.)
12-17-2021, 03:23 PM
Coachwork: Collins
Rated Cap: 18,500
Is the piece between the widows just bolted in?
What kind of frame structure is between the windows?
How much space between the top of the window opening to the bottom of that roof panel edge above it?
12-17-2021, 03:51 PM
In between the windows you will find the "Rib" structure of the bus.
Think of a ribcage of a whale, similar on the bus. The ribs make up the skeleton for attaching the body panels (skins).
It is usually made up of 16 ga metal and it is bent into what is called a "Hat channel".
Take a look at a stop sign pole and how it is formed, similar on school busses.
As far as top and bottom spacing, I do not have an exact measurement but if I had to guess, maybe 1/2" on top, under the drip rail.
On the bottom I would bring it flush to the top of the rub rail.
How school busses are made videos
Part 1 -
Part 2 -
12-18-2021, 11:15 AM
Coachwork: Collins
Rated Cap: 18,500
Thanks for the videos ewo1. That helped on knowing the design.
The trim between the windows. I would remove them. Drill the holes out larger. Then plug weld them back into position. Remove that upper step where it goes over the upper window frame. You might want to shorten those a little also. Have the top edge below the line where the new panel would contact across the bus framework.
I have a sneeky feeling that the bus frame channel is not closed off under that trim piece. So you would need to close it in to look like the upper window molding to make your new panel fit properly. I hope I am wrong.
I would plug weld the new panel in at the top. Drill the flange on it. I would do a plug weld about every 1" to 1.5". Then use automotive seam sealer to seal it from the outside.
The bottom of the panel. I would slide it under that upper trim piece. Remove as many rivets as need to pry it out enough.
I wouldn't go under 16 gauge for this panel. Anything thinner you might get beer can effect.
12-18-2021, 03:34 PM
Year: 2005
Chassis: FS65
Engine: Mercedes 6.4L
Rated Cap: just the 2 of us
I skinned 2 windows on each side of my bus. I removed all of the screws that would have prevented the sheet metal from laying flat against the bus along with the lower screws in the rain gutter. Cleaned the surfaces, jammed the sheet metal up under the rain gutter and attached with self drilling screws. Sealed with seam sealer. Because 1) I am not good with metal work and 2) I tightened the screws in the wrong order, I ended up with a ripple in the metal, right side really bad, left side is ok. I may end up re-doing the right side. I plan to paint the metal when the weather permits (next May?)
There are pics and further details in my build thread, "Don's Conversion 2.0".
12-18-2021, 04:08 PM
Year: 2006
Chassis: MVP-EF
I’ll look up your pics later, thanks! What gauge steel did you use? Sounds like I would want to go one gauge heavier.
12-18-2021, 06:13 PM
Year: 2005
Chassis: FS65
I used 24 ga. galvanized. If you plan to weld it, you probably don't want galvanized.
12-22-2021, 04:34 PM
Chassis: F33695
It's been 16 years ago but I think I remember, bent some 18ga with three edges bent back and the top bent forward, a half inch or more works, tack weld the edges on the inside and caulk, seal, what ever you want to do for a seal. Leave outside trim as caulk will make most of it dis-appear anyway. Go look at my bus but I don't have much detail on my windows.
By the way I made screens w frames just for the upper windows and silicon-ed them in, a light press fit, you have to cut them out, them buggers are in to stay. sportyrick
12-22-2021, 05:43 PM
I have a Collins. After removal of the windows I removed the exterior bumper below windows and riveted a 4” wide piece of sheet metal at the top of each window frame. Then riveted sheet metal cover over multiple windows sandwiched between the old bumper and body and to the top of the metal added to at top of window.
12-27-2021, 02:51 PM
Purchase window inserts
There is a company here in NC that custom makes inserts and other stuff for skoolie builds.
https://www.skoolie.com/shop
01-02-2022, 08:39 PM
Year: 2006
Chassis: MVP-EF
Jumping back to this, I noticed that you suggest I remove the screws below the window. Should I reinstall them afterward? I'm not really sure what they would be holding up, I assume one row of them would be to hold the body panel to the body frame underneath the window but I'm not sure what the second row would be. We're looking at doing 3 windows in a row on one side using one big panel, and 5 windows in a row on the other side, so trying to line up all of those screw holes does not look like a fun time to me...
01-05-2022, 11:19 AM
Year: 2006
Chassis: MVP-EF
More thinking on this topic...
I have 5 windows in a row to delete on one side, and 3 on the other. I was initially planning to get one big sheet of metal to cover all 5 windows, but now I'm thinking that would be an absolute nightmare to try and line up all those screw holes. I'm worried that even with a template, I'd get a fraction of an inch off, then the rest of the holes would start to skew.
Would it make more sense to just do 5 separate panels instead? Seems like it would be easier to handle as well.
09-04-2022, 05:22 PM
i put my panels on from the out side over 2 or 3 windows i riveted blind head rivets 2 inch over lap top of panel bent apx30 degree in under roof which i will caulk with 221 sika
