Old 04-23-2018, 10:45 AM   #281
Brewerbob's Avatar
Sounds like a pretty good deal at today's prices!
How "not flat" are the 4x8's? If not bent too sharply they should be fine.
Really? I don't keep up but I that was a bit pricey.
His
8x4 2 @ $50
10x4 1 @ $60
$200
Mine (not sure which was the 5 and which was the 6)
8x4 5pcs/6pcs
10x4 6pcs/5pcs
$560
Either way I bought mine last year.
Old 04-23-2018, 10:49 AM   #282
You bought way more and last year steel was MUCH cheaper.
Old 04-23-2018, 11:05 AM   #283
Brewerbob's Avatar
Yand last year steel was MUCH cheaper.
I finally done something right? Yay!!
Now I just need to find some Dodge scissor jacks and get this sucker leveled so I can cut the top off.
Old 04-23-2018, 11:22 AM   #284
IDk, just use some all-thread.
Old 04-23-2018, 11:43 AM   #285
Brewerbob's Avatar
No no; that I've got. I want the scissor jacks for leveling the bus. The Dodge jacks have a bolt head instead of that damn annoying loop. I can use a ratchet or air gun on it. If I don't lift the bus (which I don't plan on doing), I can torque them all to the same value so there won't be any sagging.
Old 04-23-2018, 01:28 PM   #286
$20 bottle jacks did a fantastic job leveling mine. I didn't lift my bus, just jacked it in various points till it was as level as we could get it.
Old 04-23-2018, 01:35 PM   #287
Brewerbob's Avatar
The jacks are $7 so instead of using blocks of wood (which I'd have to find/buy) I'm thinking of using just the jacks. I've got a few cinderblocks to get them up high enough. Then I don't have to use wedges or anything like that.
Old 04-23-2018, 02:53 PM   #288
Chassis: Saf-T-Liner MVP ER
So what do you do when your air-nibbler decides to nibble no more?
You stick a cutting disk on the angle-grinder, is what you do, and follow the lines.
Four pieces to cover ten windows now cut to size:
Steve Bracken
Build Thread
Old 04-23-2018, 03:03 PM   #289
Brewerbob's Avatar
Is the nibbler any easier? I have both. What I think I'm going to do is clamp my 7 foot level to the sheet and use it as a fence to run the angle grinder along. But no reason I couldn't do the same and use the nibbler.
Nice cat.
Old 04-23-2018, 03:40 PM   #290
Nice cat.
The nibbler gives a clean edge and can be run along a fence. It's a bit slower than the cutting disk but the resulting edge is better. Needs a big compressor.
No good if the cutter breaks and replacements are made of unobtanium.
Steve Bracken
Build Thread
Old 04-23-2018, 06:40 PM   #291
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Be careful with the cinder blocks.
They can and will break and crack very easily
Old 04-24-2018, 07:04 AM   #292
Brewerbob's Avatar
Mine is a Horrible Freight special.
Old 04-24-2018, 07:21 AM   #293
I've never had a bad HF tool yet. They don't make tools, so it will depend on who they bought it from.
They are pretty simple devices, so if the cutters are available it should be fine.
Mine was Campbell Hausfeld, and they discontinued it with, seemingly, no consumables available. It's possible that the cutter from another brand would fit it.
While on the subject of Harbor Freight. I'm about to drop $700 on their Predator 3500 Inverter Generator. I've watched dozens of videos, read loads of reviews and it's getting harder to see how Honda justify $2000 for what amounts to the same thing.
Steve Bracken
Build Thread
Old 04-24-2018, 07:28 AM   #294
Brewerbob's Avatar
Cinderblocks' strength is in compression. That said, I'm going to get some plywood for "footers" and have the blocks positioned the same way they are in a wall.
Also, I'm not lifting the bus off the ground. Worst case I'll have the suspension slack.
Old 04-24-2018, 07:58 AM   #295
those HF bottle jacks ROCK!! get some of those to level off the 4 corners.. when I was doing my trans last year I had those stay up for a couple weeks without deflating... im thinking we had a couople under EC's bus that held solidly too when we cut his top off
Old 04-24-2018, 08:26 AM   #296
Brewerbob's Avatar
I have a 6 ton bottle and a shop jack. I had another smaller bottle jack somewhere but I haven't seen it in years. I also have a set of jack stands that are 6 or 10 ton. I need to see how tall they are in comparison to the frame rail.
In the perfect world, I'd have the bus on concrete and in the air on a dozen jack stands but then I wouldn't be able to blame the crooked sheet metal on setup.
Old 04-24-2018, 08:37 AM   #297
Brewerbob's Avatar
I want a diesel genny. I'll be lucky to get away with $2000. Every once in awhile I check the auction sites and CL but not near often enough.
Old 04-24-2018, 08:51 AM   #298
weboughtabus's Avatar
Coachwork: Corbeil
Engine: Ford PowerStroke Diesel 6.0
Rated Cap: GVWR 11,500
I don't know your plans, but I've been looking at LPG/Dual Fuel/Tri Fuel conversions and came across this kit. It doesn't specify which models it's compatible with, but the Predator 3500 has a 212cc engine. I've reached out to VPower and can let you know if it's a match, if you're interested.
EDIT:
Just got a response - no dice.
weboughtabus is offline   Reply With Quote
Old 04-24-2018, 09:11 AM   #299
Brewerbob's Avatar
EDIT:
Well, I guess my slow ass internet gave you a chance to update.
I've seen gasoline and LP. I know you can convert LP and CNG. I have NOT seen anything paired with diesel. Or more likely nothing "worth" remembering. What I'd really like is duel fuel being gasoline or diesel.
Some of the fancy hiking stoves will burn gasoline, white fuel, or diesel but all they are trying to do is make heat with fire.
Anywho, I'm a LONG LONG way away from doing anything electrical so if you do find something and think to remember, give me an update.
Old 04-24-2018, 10:22 AM   #300
Coachwork: Corbeil
I'll happily keep an eye out for something along those lines. I'm planning to carry LPG for cooking, so to me it's more sensible to run off of LPG than gasoline so I don't have to tote three different fuels. If I could find a small, quiet, reasonably-priced diesel generator, I might change my mind, but my I can't find a genie in any of the lamps I rub.
