Old 04-24-2018, 10:51 AM   #301
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
https://www.target.com/p/7500-watt-d...E&gclsrc=aw.ds
A dual fuel for ya, idk anything about the brand
Whatthefak is offline   Reply With Quote
Old 04-24-2018, 11:03 AM   #302
Brewerbob's Avatar
Originally Posted by weboughtabus View Post
I'll happily keep an eye out for something along those lines. I'm planning to carry LPG for cooking, so to me it's more sensible to run off of LPG than gasoline so I don't have to tote three different fuels. If I could find a small, quiet, reasonably-priced diesel generator, I might change my mind, but my I can't find a genie in any of the lamps I rub.
I'm trying to stay single source. Diesel water heat, diesel heat, and diesel stove. Guess I'd be totally hosed if the tank ran dry. But I'd like a second tank just to extend the driving range if nothing else. A 40ft bus with a 60 gallon tank; what were they thinking?!! I'd like to ADD (not replace) a 100 gallon tank. There's plenty of room between the frame rails in front of and behind the original tank.
Old 04-24-2018, 11:09 AM   #303
Brewerbob's Avatar
Not for me; that's gasoline and LP. You can buy those as Tractor Supply to Lowes and everything in between.
Old 04-24-2018, 11:52 AM   #304
Brewerbob's Avatar
Not quite what I meant by dual fuel but interesting nonetheless...
https://www.treehugger.com/cars/dual...t-engines.html
https://link.springer.com/article/10...239-017-0092-7
Old 04-24-2018, 12:09 PM   #305
Brewerbob's Avatar
Here you can geek to your heart's content:
https://www.sciencedirect.com/scienc...16236117309298
Old 04-28-2018, 06:47 PM   #306
Chassis: Saf-T-Liner MVP ER
Windows out and skins ready to install:
Steve Bracken
Build Thread
Old 04-29-2018, 04:40 PM   #307
Am I glad that is done.
That was a long, hard day.
Steve Bracken
Build Thread
Old 05-01-2018, 07:40 PM   #308
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Attachment 21362
Attachment 21363
Attachment 21364
That's the downside of searching through the forum with certain words...you sometimes miss the build threads! Exactly what I had been looking for. Any chance you could get a few up close shots of what you did? This'll be my project within the next week or so
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 05-01-2018, 07:48 PM   #309
Yes.
It's getting dark now so I'll try to get them tomorrow.
Steve Bracken
Build Thread
Old 05-01-2018, 07:55 PM   #310
Okay, got some close-ups showing various aspects including some from inside showing where the new screws come through:
It looks a little rough in some places, but once the sealant is tidied up and the panels painted, they will look just fine.
Bottom two pics are sideways.
Steve Bracken
Build Thread
Old 05-01-2018, 08:13 PM   #311
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
You, Sir, are amazing. Thank you so much! I feel much better about the project now. I'll get a better view on computer later when I'm home than on this phone.
Old 05-01-2018, 08:32 PM   #312
You're very welcome.
Steve Bracken
Build Thread
Old 05-01-2018, 08:38 PM   #313
.... and ... I sold three of the windows.
First return I've had that puts money back in the kitty.
Steve Bracken
Build Thread
Old 05-03-2018, 01:18 PM   #314
Brewerbob's Avatar
I'm keeping mine. Will likely use them to build a greenhouse oneday someday.
Old 05-03-2018, 05:04 PM   #315
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
My windows will be for my friends greenhouse when I get out to new Mexico after my build is completed. Once I'm done and quit my jobs, I'll be out there helping him build up his property some
Old 05-04-2018, 11:12 AM   #316
Brewerbob's Avatar
Attachment 21483
Armchair critic, ... is that over the rub rail? Mine will be under the oem metal at the top of the windows, over the metal at the bottom of the windows and under the rub rail. It's going to be fun to try to get it to "pop" into place.
Old 05-04-2018, 11:21 AM   #317
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Thomas and Bluebird does this differently. The top of our thomas rub rails are already underneath the sheet metal, unlike your bluebird that is right on top of the metal. We would have to remove metal skin to remove the rub rail, which isn't really necessary since the rub rail is covered from factory. What he did, and what I will do, is the sheet sitting flush where the rub rail is under the bus skin where the little bump is, so it lays on flush with that
Old 05-04-2018, 04:46 PM   #318
Exactly as he said, just like this:
Steve Bracken
Build Thread
Old 05-05-2018, 01:36 AM   #319
mikerob643's Avatar
Chassis: Vista 36pp
Engine: 7.3 L diesel
Are those self tapping screws you used for the new skins? I have been going back and forth between doing mine with rivets or self tapping screws. I would rather use the screws , but didn't really know the pros and cons.
The new skins look great though congrats on getting that done
mikerob643 is offline   Reply With Quote
Old 05-05-2018, 08:08 AM   #320
Off topic question....
Steve- are you a football fan?
