03-22-2018, 01:13 PM
#261
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Lookin good Steve! I sure wish I had a helper AND that much headroom to work with!
03-22-2018, 01:27 PM
#262
Chassis: Saf-T-Liner MVP ER
Yeah, about the "helper". She crapped out on me when there were heavy plywood panels to shift
Took me two days to do that on my own.
Trying to decide what to do next.
I have calculated that I will have 74 1/2" headroom in the center when the ceiling is in.
03-22-2018, 02:56 PM
#263
Coachwork: Thomas MVP
Engine: Cat 3126B
Rated Cap: 20800
That is pretty decent headroom while still being well insulated. One of our daughters is interested in a skoolie but her husband is over 6' and a little apprehensive about enough headroom. My plans are similar to yours so hopefully he will be able to lay those fears to rest. Very good progress so far, keep it up.
Desmond
03-22-2018, 05:21 PM
#264
Desmond
I would have raised the roof had I bought one with a standard ceiling.
03-22-2018, 06:43 PM
#265
Engine: Cat 3126B
Rated Cap: 20800
Thank God for right-angle die grinders, and for having one
Now the coolant pipes to the front heater can go under the bus instead of through it:
Attachment 19921
Any self-respecting bus this age would be rusty, and the metal would be easier to cut !!!
What did you use to make the cuts, angle grinder?
Desmond
03-22-2018, 06:48 PM
#266
Engine: Cat 3126B
Rated Cap: 20800
Duh, read the whole thing Desmond!
03-22-2018, 06:57 PM
#267
lol ...
04-15-2018, 03:06 AM
#268
Chassis: HDX
Engine: 3126 7.2
04-15-2018, 12:01 PM
#269
Originally Posted by SilentReprieve
Last few weeks have been a little slow, but next order of business is:
Delete 10 windows, 5 on each side (need steel)
Delete upper lights using spare steel
Tidy inside and spray-foam walls and ceiling.
I need to go get some sheet steel. Part of the delay was caused by needing to rebuild my trailer. It now has a fancy new bed and led lights, but that took a while and the weather hasn't been too friendly.
04-16-2018, 09:24 PM
#270
Rated Cap: 35
like the floating floor. what is the final floor covering going to be?
04-16-2018, 09:39 PM
#271
Can't decide.
I like the vinyl planking, but it's not cheap. I have access to plenty of reclaimed lumber, and I have a Delta 15" Planer ... so maybe a full wood floor.
04-17-2018, 11:16 AM
#272
Can't decide.
Nice, I have a borrowed 12".
And since you (kinda) mentioned it, pallet planks actually clean up fairly nice. Just FYI for other projects you may have on hand. It's hard to beat free tho breaking them down is a pain in the butt.
04-17-2018, 04:45 PM
#273
I have a very nice Delta Unisaw too, with a 54" Biesmeyer fence.
I bought the saw and the planer from a cabinet firm that went broke. Think I paid around $750 for both. That was a good day
Anyway, it does mean I can rip and plane wood easily, and fast.
04-18-2018, 09:01 AM
#274
I have 2 problems... my uncle had a full woodshop and he said he literally gave away his equipment to his lawn guy because no one wanted to buy it. Second, I don't have room for a 54" even if you gave me one. Tho I would certainly make room somewhere!!
04-18-2018, 10:53 AM
#275
They fit very nicely into most living-rooms ... alongside the motorcycle
04-18-2018, 11:17 AM
#276
True but running a 50 foot 220v/30 amp extension cord is a pain in the butt.
The motorcycle is rusting away in the driveway. It belongs to the ex.
04-23-2018, 10:19 AM
#277
Went and fetched the sheet steel this morning.
Not happy that the 8 x 4 sheets are not flat, but I think I can work around it. The 10 x 4 is perfect.
8x4 2 @ $50
10x4 1 @ $60
$200 total with tax ... less than I thought. It's 18-gauge.
04-23-2018, 10:25 AM
#278
8x4 2 @ $50
10x4 1 @ $60
Sounds like a pretty good deal at today's prices!
How "not flat" are the 4x8's? If not bent too sharply they should be fine.
04-23-2018, 10:39 AM
#279
They are kinda "wavy" where they have been sitting on supports for too long.
They should be fine, I need to cut them anyway.
The supplier had "old stock". When I called I was quoted $75 and $85 but when I got there he charged $50 and $60.
04-23-2018, 10:44 AM
#280
Oh, that's pretty standard. No worries, they'll be just fine.
Imagine how much worse the thinner stuff bows!
