Originally Posted by Big dog
we build professional tiny houses on bus chassis all the time, the advantages are huge!
better breaks, better tire ratings, better safety, better better better!!!!! you cant go wrong
the bus body is built to be a structural box, but its independent of the bus chassis. so we cut the body off right behind the drive area and build a tiny house on the back 30 feet. we are building one now that is a short bus to use as a mobile shop for our mobile rv services. its an international chassis DT 360 (250 HP) with MT 643 Allison ( this combination will fly! over 80 on the highway) but we are adding a twist to this build, we are using a 1964 chevy truck cab and front clip so it will have the front end of a 1964
chevy truck and a tiny house on the back. we are planning to build this unit this year.
How does your Tiny Home product differ from a DIY RV?
Are the necessary safety inspections performed by a licensed state or county entity?
Are "homeowners" able to obtain:
- Certificate of Occupancy from their local AHJ?
- Homestead tax Exemption from the Property Appraiser?
- Homeowners Insurance?
What additions or changes advance the bus from an RV to a tiny House?
Are we simply redefining "stationery RV" and replacing it with "tiny house"?
You used the word "professional", meaning licensed/bonded/insured Electricians, Plumbers, HVAC, permitted, inspected & certified? Not amateurs, Pros.
A manufactured "Park Model" RV can receive all of the aformentioned homestead inspections and benefits, the same as an on-slab, brick & mortar home. The park model rv manufacturers have upgraded their product and negotiated the licensing & certifications to define their product as a Perminant Residental Structure.
Did you?
