Old 09-27-2020, 12:11 PM   #1
Tile on a Budget?
Hi all,
I am trying to tile our shower on a budget, from the research I have done I am not finding a ton online with affordable tile. Any suggestions would be amazing! Thanks!
Nikki is offline   Reply With Quote
Old 09-27-2020, 12:16 PM   #2
I wouldn’t try to tile on a budget. Ideally you’d want to use the foam core tile backer and it ain’t cheap. FRP is a good choice if you’re in a budget.
Old 09-27-2020, 02:14 PM   #3
Thank you! I think after a little more research and understanding the prices I am willing to pay a little more to do tile... I have seen recommendations on using the polymer grout to prevent cracking, etc.
Any thoughts??
Old 09-27-2020, 02:34 PM   #4
CHeck this thread
https://www.skoolie.net/forums/f50/w...ngs-29151.html
The tile backer, sealant, tile, thinset and grout was about $650.
When you figure the tile get 15% more than you need as measured.
When you saw tile wear eye protection especially if it’s glass tile like I used.
But how about colored mica in resin? You’d have to dry fit all the panels then resin flat, then assemble. It would be cheaper and lighter. Just a thought.
